Question about Hoover Vacuums
How to replace belt on hoover runabout deluxe
5 Suggested Answers
SOURCE: changing belt
  1. how to change belt on hoover vacumn
Posted on Aug 16, 2008
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
Vac Belts
  • 701 Answers
SOURCE: I need to open up this Hoover Uprite Runabout
You will find them on the bottom of the machine on the brush roll cover. This is the belt you need:
Hoover Runabout Deluxe U5064-940 Belt
Posted on Dec 08, 2009
WonderTech
  • 268 Answers
SOURCE: how do you replace the belt on a hoover runabout
This link will take you to a site with instructions and illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Posted on Mar 23, 2010
How to fix height adjuster on hoover runabout vacuum?
It probably is not broken. It only operates when you recline the handle into the vacuuming position. At that time it goes to whatever setting you have it set on. When it is in the full upright position, it will be in the highest setting no matter where the nob is set.
May 17, 2014 | Hoover Runabout U50-940 Bagged Upright...
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
Does the hoover runabout u427-930 have a filter? I replaced the belt and next to the light bulb was a square gray mat that looked like a filter covering a screen full of holes that looked like the motor...
From doing a search on the internet and hoovers website it looks as if this unit does not have a filter. Such as a hepa that needs to be replaced or that is washable. So i think you are safe and dont need to worry about it.
Aug 27, 2010 | Hoover Elite U5061-900 Bagged Upright...
How do you replace the belt on a hoover runabout sweeper.
Hope this helps
Mar 21, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Replacing vacuum belt
thanks for your concern...........a friend of mine said you very carefully have to pry the top off and you can get to the belt.............it worked and i didn't break anything.........it now works fine............thank you again.
May 22, 2008 | Vacuums
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
120 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
