Question about Dryers
Whirlpool dryer will not start the start buttton click when pressed and the timer works if i have the door open and press the start button there is no click so i figured it was not the door swich wed5840sw0 is the model number thanks
    President:
  • 3,074 Answers
It may be the reset switch to reset the switch unplug the dryer, remove the power cable and back cover completely, two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch push the button on the left to reset the switch.
Posted on Sep 05, 2010
  • 262 Answers
The first thing to check on a electric dryer is the power.
I know It look like you have power but you have a 220V dryer and it need both sides of power to work.
If you can't ckeck for proper power at the outlet then please at least ckeck your breaker box and maker sure you turn both switches off and then back on to make sure that one site of the breaker did not trip. Then check your dryer to see if this did not solve your problem. ((((( I flip a breaker at least once a month for a customer and recive $60.00 for doing so :) ))))))
Ok if this did not solve your problem.
When you push the button for start do you here a hum noise ??? if so Most common problem would be the motor.
No hum.... Open dryer door and turn drum by hand and close door and retry dryer.
No Hum....
Now it get real fun !!! The start switch needs to be checked, Then the Thermal Fuse and the High limit thermostat.
In most cases this is going to be forign to you and you should call a tech for service.
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Dryer won't start. Door is fully closed, I checked the circuit breaker, the lint catch is fully in place. set timer and push start, but nothing happens
You can check the door switch...its a small lever like button that the door pushes inward when closed...with the door open press it softly and listen for a click...if you have a light inside the drum it should go out when you press the switch..If its not that.. it could be a the timer switch/dial and those could cost upward of a $100...these part can found with any local repair shop/person Good Luck
Apr 20, 2010 | Whirlpool Dryers
Hit start button but dryer will not start can hear the timer running
Open the dryer door and press the door switch , to make sure you hear a distinct " click " . If the door switch seems ok , then remove the rear dryer panel ( UNPLUG DRYER FIRST ) . On the blower housing , you will see a white 1" long piece ( thermal fuse ) with 2 wires plugged onto it . This is the piece you need to replace . #3392519 is the Whirlpool part number .
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
Gas dryer won't start
Hi!!! check your off and in button.get and ohm meter and maker sure that it has conduct when you press the button.also check thermal fuze it should have conduct, if not replace it..Good luck.
Jan 23, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
