The burner only comes on first time . If the dryer has not been used and is at room temp, the burner will come on the first time, heat to about 110 deg, measured at the lint screen then go out. The igniter will continue to come on and I hear a solenoid click but the burner will not come on again. It appears that the only time the burner comes on is if the entire dryer has cooled down to room temp again.
My whirlpool gas dryers 'dry miser' is not advancing, but the timed drying seems to work fine. I...
(More)
My whirlpool gas dryers 'dry miser' is not advancing, but the timed drying seems to work fine. I have checked the thermostats and coils for continuity and proper resistance, checked for lint build up, and have taken to banging my head off the desk. Ideas?
my lg dryer model dlg2524w is not drying all the way and the dry light keeps flashing, the cooling...
(More)
my lg dryer model dlg2524w is not drying all the way and the dry light keeps flashing, the cooling light stays on all the time and some times the change filter light comes on
The dryer runs through all cycles, but never heats at all. I think the ignitor is bad. If it were...
(More)
The dryer runs through all cycles, but never heats at all. I think the ignitor is bad. If it were the thermostat I assume it would heat up some. I know the gas is hooked up correctly and on, but I get absolutely NO heat. There is no smell of gas in the dryer or anywhere around it.
