Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Motor seems to work but doesn't turn the pulley doesn't sound like it normally does
I have a Ingersoll Rand Compressor model# H15T4 and it constantly pops PRV. What do thing is the problem. Thanks.
Posted on Nov 01, 2010
No power in the brush
You may have either excess friction in a bearing or a slipping belt. Unplug the vacuum cleaner, remove the bottom plate, try turning the motor pulley by hand. If it is very hard to turn, remove the belt, then check the brush bearings and the motor bearings to see where the gum-up is. If it turns normally, try turning the motor pulley with one hand while holding the brush with the other to see if there is any slip in the belt or in the brush pulley. If the belt is loose, first check for loose screws or broken motor mounting posts. If those are all good, and the motor is as far back as the screw mounts let it go, the belt is probably stretched and should be replaced.
Jun 25, 2015 | Vacuums
Eureka 9410 upright vacuum motor
They normally have a reverse thread nut on top then just pushed down on a tapered end so needs to be levered off normally a wide flat blade paint scraper etc can help spead load so fan doesnt break or distort
Apr 13, 2017 | Vacuums
Jeep Grand Cherokee with new belt and still squeaks.
The pulley you describe sounds like the idle pulley and it should be straight and if you remove the belt and turn the pulley it should roll free and not bind. In short I would change the pulley as it has a bad bearing in it.
May 23, 2017 | 1996 Jeep Grand Cherokee
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I hear a noise coming from the serpentine belt area. Sounds like a bearing. I just put on a new belt and the noise is still there. The tensioner seems to be working fine. What could this be?
Each pulley is has a bearing. The best way to check it is to remove the belt and spin each pulley, (except the crank pulley wont spin) and listen to each one normally a tensioner pulley or idler pulley is the problem. Note: not all pulley will turn with the exact freeness in feeling, for instance it will be harder to turn the power steering pulley than it will to turn the ideler pulley but just listen to the noise. If you got a bad one it will sound like grinding rocks. Good luck.
Feb 28, 2010 | 2004 Toyota Corolla
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
Motor not turning drum but heaters working ok
Your belt may be stretched and is slipping on the motor pulley.Belt tension pulley may be sticking. May be a bad lint buildup on the blower wheel.
And yes, finally, maybe a bad motor.
Jul 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Washer doesn't engage the drum
a ratcheting sound generally indicates some object (wire of sorts) tried going down drain but cant make it out but motor not turning drum over is something else, to check drain remove lower cover and open pump cleanout also feel the rubber hose from bottom of tub to pump to see if a object is in it. take hose off pump to clean out hose. if this is older duet check nut on rear pulley and tighten..
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Crankshaft pulley
You will, very soon, need a crank pulley assembly; This one is on its last legs due to the rubber rotting out...accordianman
Nov 09, 2008 | 1997 Mitsubishi Galant
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
136 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
