Question about Maytag Neptune MCE8000AY Electric Dryer
Lower dryer tumbler will not heat up, upper dryer part works fine
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer takes too long to dry
may be the solonoid. mine did that to where the tumbler worked fine, but heat was really weak..$40.part and fairly easy fix
Apr 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
Breaker popped, so went and turned it back on. Now there is no heat. What could be the problem?
In your dryer behind the tumbler there are coils with insulators. up against the dryer wall their should be many holes that allow the heat to come into the tumbler. run your dryer about 3 minutes with settings on heat , then open the door and peer thru to the back while the tumbler is spinning. if you don't see part or full radiat heat. the heating coils will have to be replaced. you can purchase them from most appliance parts store. just make sure you provide the brand and model # and possibly the ser#. good luck!
Dec 30, 2010 | Dryers
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
Lower dryer has no heat for drying. Upper dryer continues to work with heat. Can it be fixed?
heatman101
Oct 03, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Upper limit problem
check for shorted heating element ,coil will make contact with heater tank and bypass t-stats.If your limit is a thermal fuse you must change lower tstat as well.
Jun 17, 2009 | Whirlpool LER5636P Electric Dryer
Paddle in dryer tumbler broke off need to know how to attach new one.
Hi, UNPLUG the dryer. You should find two screws in the front lower part of the panel where it angels in. Remove those screws and pull the bottom toward you. The front panel should then release. Now you will need to locate the screws in each of the upper corners that hold the top to the cabinet. They will probably be 3/8" screws. The top should lift up. You can put the parts on this way. THe old screws are probably laying in the bottom of the dryer. You might need to add metal washers if the holes have longated. If I can assist you fyrther, please let me know.
Thanks
Vic
May 16, 2009 | Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
