Question about Vacuums
I have a hotpoint microwave and the turn table does not turn when something heavy is on it. for example it turns if you warm a cup of coffee. is it a belt or the motor slipping? if so, in either case, can i fix it myself? Thanks, ron
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 06, 2010
I recently purchased a 2lb bread maker. But cannot find the manual or recipe book so I can use it. I brought it from QVC. Can you tell me where I can get this information. I would love to start using...
If you want to use the bread machine immediatly, boxed bread mixes from grocery stores will have generic instructions on the back of the box that can be used universally by most bread making machines. However, if you are wanting the manual and recipies to the particular machine, sometimes the place you purchased it from will allow you to photocopy one from a new one on the shelf. You would need your receipt to prove the purchase. Google Search is also an excellent way to download copies. The contact information on the box will too. In the meanwhile, if you want to make perfect bread follow this recipe BUT>>>do not use the machine for this recipe, use a large bowl to raise the dough.
4 large bread loaf pans, lightly greased with 1 teaspoon vegetable oil each. Set aside
4-6 cups+ flour
1/3 cup evaporated milk
3 2/3 cups water
1/4 cup active dry yeast
1/4 cup salad oil
1/8 cup table salt
1/6 cup sugar
Put the water and evaporated milk in a glass bowl and microwave to 120*~about 2 minutes. It should feel very warm to the touch but not as hot as a cup of hot coffee.
while microwaving, take a second very large bowl (big enough to hold a family size bag of chips)
put the salad oil, sugar, salt and yeast in and stir till mixed.
Add the very warm but NOT extremely hot milk water to the dry mixture. Use a swizzer to mix. Start adding the flour till very thick. Take swizzer out and add more flour gradually until it can't absorb more and is no longer sticking to the sides of the bowl. Shake more flour on a clean counter top and work the dough 3 minutes until smooth and not sticking to the counter. Place dough in another very large bowl. Cover with plastic wrap, place in a warm area such as the vent area of a 225* oven to rise. Punch down after double in size (about 30 minutes). Divide into 4 equal portions. Shape and place in pans. Rise 15 more minutes. Heat oven to 375* bake till golden brown on top and a finger tapping sounds hollow.
Wrap in plastic wrap when cooled slightly to keep moist. Refrigerate loaves to keep longer.
This recipe can be used for cinnamon rolls, clover leaf buns, pizza bread sticks or all 4 if you divide it up! Enjoy....I'm also a competition baker!
Sep 22, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
I need the manual for farberware fsu 236 coffee maker. How much coffee for 36 cups of water?
For medium strength coffee, start with about 2 cups of coffee. Adjust for taste in later batches until it's the strength you want.
Nov 24, 2010 | Vacuums
How much water and coffee is needed for a GE 42 cup coffee urn? Thanks,
8 X 42 = 336 ounces / by 128 = 2.625 gallons of water
1 cup of coffee/10 cups = 4cups of coffee for the batch...
heatman101
Nov 17, 2010 | Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
