Just bought new washer, Maytag EPIC, Won't fill with water and F-30 flashes
  • Anonymous Jun 20, 2008
    Our machine is giving us the same error message. The machine was delivered yesterday, and we've run a couple of loads, but now it refuses to work.
  • 101 Answers
Check the drain pump, make sure it close when its filling up water. How can you tell if the pump is close. When its filling up water you should hear a noise like the gear it moving. The drain should not have water coming out.
Posted on May 12, 2008
Maytag front load FH error msg
May be a water pressure sensor problem.
This tells it when the tub is full.
start with this video
https://www.youtube.com/watch?v=2pIVkAxWSXg
Nov 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
I would like to know how many gallons of water this machine uses per washload. Maytag Epic Front load Washing Machine Model # MFW9800TQO
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Mar 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
When washer starts to wash it beeps and flashes the letters FH.
Hi
Error FH means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 17, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a Maytag front loader Mod. MFW9700SQ1 - I get an error code of H and then F flashing. The machine stops washing. What could be the problem?
Hi
Error HF means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Epic front load washer is dripping a small amount of water from the water entry point in the tub. Is this normal after washing a load of clothes? I have not noticed it before.
I do not think this is normal. This may be a sign that your water fill valve is going bad. I would recommend shutting off your water supply valves when not in use and do not leave unattended when in use in case it gets worse. I would get repaired as soon as possible.
Mar 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
I own a maytag epic z front loading washer and dryer and when i wash clothes they never get all the way wet and i end up having to rewash them. Im not sure what else to do.
ck to be sure drain hose is not more than 6-8 inches in standpipe top of standpile nees to be 30-36 inches above floor and drain hose should be too snug in standpipe ..any of above conditions may result in water siphoning out and not leaving enough water in tub ..washer only uses 5-6 gals per fill based on load so if water is being siphoned out doesn't leave much left
Sep 02, 2008 | Maytag Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
