Question about AT&T Palm Centro Cell Phone - White
I have palm centro I dropped it and then I can see anything on the screen. I got my replacement phone and now the Verizon store says they can't even transfer my phone numbers or memos. How can I duplicate or copy whatever is in my broken palm centro. Is there a a program, the hot sync is not working either. Is there a special usb cord that I can buy to plug in th eompcuter to read the plam centro
5 Suggested Answers
zohail
  • 1223 Answers
SOURCE: New touchscreen does not work.
Pls first hard reset ur phone like this if it doesnt help then go to AT&T it is a possible Touch Panel Failure they will do it Free if u are aunder warranty i think u are
but pls try first RESET here
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/887_en.html#hard
and also see this for New user info
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/45008_en.html
Posted on May 08, 2009
  • 6 Answers
SOURCE: how do I transfer data from Palm Tungsten E OS to
You can use the infrared to transfer items on these devices, here is a short description of how to beam items between units: http://www.ehow.com/how_6506_beam-file-another.html If you need more advanced options, try the app FileZ (just google "FileZ Palm" it's free), FileZ can unlock some locked appications so that you can beam them.
Posted on Jun 06, 2009
  • 32 Answers
SOURCE: Palm centro screen blank without droping it.
check the flex connectter for the screen make sure its in there all the way on the mother board.
Posted on Dec 16, 2009
list478
  • 5 Answers
SOURCE: how do i tranfer my contacts from my palm centro
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Posted on Sep 16, 2010
Calendar on phone is good, calendar on computer is gone I tried hot sync with just the calendar only, but that freezes. what should I do
1.Bought Palm centro with freezing up problem then returned and got another one.
2. Second Palm centro again with freezing up with additional screen flickering problem....buy one problem take another problem....good huh? buy one take one..
3. Third Palm centro after returning the second, now I stil have and inherited the freezing up problem .....you always inherit the freezing up problem even as many times as you changed your PALM CENTRO.
conclusion:
I WILL NEVER BUY PALM CELLPHONE AGAIN.
Jun 15, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
Dec 16, 2009 | AT&T Palm Centro Cell Phone - White
Hi. I have a palm Centro phone through Verizon with a cracked screen. How do I go about replacing the screen?
If your Centro is in warranty then you should probably take it to a Verizon store and let them repair or replace it.
If you want to try to fix it yourself, a Google search for "palm centro screen replacement" will show you several sources for the parts needed. There are also some special tools you may need to buy. This video shows the process and should help you decide if this is something you want to try:
Oct 12, 2009 | Palm Treo 500 Centro
CANT USE ANY BUTTONS ONLY TOUCH SCREEN
it is toast, yes dropping does it, so does camping, (moisture). if you got the insurance then you are ok just go replace it cheap, and pray tht you can get your data on the new one.
Aug 18, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro has a faulty headset jack. I can hear sound through the (Plantronics, wired) headset, but no one can hear me, neither through headset nor without a headset. Centro acts as if there's a...
i had this happen to me recently and found out whats wrong the phones kinda slow and thinks the headphones are still plugged in and if you take out the battery and put it back in it saves that you had somthing plugged in and dosent help. For some people they can fix this as easily as plugging the headset back in and pulling it out slowly but for me this didnt work so what i did is, i turned on pocket tunes and you souldnt hear anything and make sure your sound is turned on, then take a small pin and stick it in the headphone jack and wiggle it around untill you hear somthing and then quickley pull out the pin.
Hope this helps
Jul 09, 2009 | Sprint Centro Smartphone
Transfer of treo programs to Palm Centro
The Centro and Treo are virtually identical. Have you tried reinstalling the applications from scratch on the Centro (vs. relying on Palm synch to automatically synch all applications)?
Aug 25, 2008 | Palm Treo 600 Handheld
AT&T Palm Centro Cell Phone - White Logo
46 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
