Question about HP iPAQ HX4700 Pocket PC
Permanent white arrow cursor
After using bluetooth the otherday I now have a white arrow cursor stuck in the centre of my screen. Soft reboot does not remove it. I'm sure I've heard of this problem before but cannot remember how to rectify. Any ideas?
    Genius:
  • 1,019 Answers
Try This:-
1:- Press And Hold The Contacts And Mail Buttons.
2:- Then Doing a soft reset, you should be prompted with To perform a clean reset, Press the Calender Button.
Mike @ Compurepair.
Posted on May 12, 2008
Cursor freezes or is erratic
Ow, I have had this problem myself. Do you have an iPhone or other Apple device that you've connected lately?
I am assuming your mouse is either Bluetooth or uses a proprietary 'dobgle'...Which?
Dec 28, 2013 | Computers & Internet
Erratic cursor ms media centre wireless keyboard
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
Frozen cursor
Change mouse and/or cord.... and reboot...
Sep 19, 2012 | Acer eMachines 520-2890 Notebook
Help.. my acer aspire computer screen has turned vertical on my notebook and the cursor isn't working.. what do I do?
Well, to get the screen back to normal, press Ctrl + Alt + Up Arrow. As for the cursor, try rebooting the computer after changing the screen back to normal. If that doesn't work, try another external mouse to get to the mouse settings from the control panel and see if anything has changed.
I hope this helps! Thank you for using FixYa!
Jul 14, 2011 | Computers & Internet
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
No toolbar/ deskbar
you probably moved it by accident try moving your mouse cursor near the bottom or sides of the screen, when the cursor almost dissapears, it should change from a single white arrow to a double (up/down) arrow. click left and drag up, normally you bar should reappear.
Feb 23, 2010 | Acer Computers & Internet
Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Cursor stuck in middle of screen
If you are using an external mouse, unplug it and see if it will go with the pad.If it works with the pad then its the exteranal mouse.
If you are using the pad you may have to replace the pad or recalibrate it using the pointer device, you can use the tab key to go through to the start menu then use the arrow keys to go to control panel.
Hope this helps
Nov 28, 2007 | Compaq Presario 5000 PC Desktop
HP iPAQ HX4700 Pocket PC Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
