Schematics for Model # 5KCP39JGM440T GE Commercial Motors by REGAL-BELOIT 3386 1/3 hp 208-230 volt Blower Motor
    Genius:
  • 1,075 Answers
I really take my hat off to you for telling me all about the model,but why write this?????????im a engineer here to help people and you waste my time.or mybe you have a problem that you forgot to mention.adrian,,,,,,,
Posted on Sep 05, 2010
  • april_ousoon May 07, 2012
    The motor I took off has two wires coming out and the new one has five. I dont know where they go now?
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
Are the GE HC39GE242A and the GE HC39GE242 electric motors interchangeable?
just read on the motor and get the volts,RPM and amps and this will get you the correct motor.
Sep 11, 2014 | Heating & Cooling
Need circuit board diagram for CES0110057-2
Are you positive the motors not shot? In my opinion, that's more likely, but Im going of what I know. Why do you think its the board?
Oct 20, 2012 | GE 1/2 Hp Ecm Blower Motor Hd44ae121...
Regal shuts off when turn signal is activated
The alternator is most likely the problem,it is not charging,or not charging enough.If you have a volt meter check the voltage at the battery with the car running,the headlights on,and the ac on high blower motor,the volts should be in the range of 13.65 volts ,to 14.25 volts.
Mar 19, 2010 | 1997 Buick Riviera
What is a reasonable price for a fan motor to be installed in a air conditioner 3.5 ton unit
I am retired now but a few years ago I sold the motors:
MOTOR SPECIALS Blower motors
1/4 HP 220v____82.17____63984
1/3 HP 220v____84.02____63986
1/2 HP 220v____103.00____63988
1/4 HP 115v____80.00____63983
1/3 HP 115v____82.17____63985
1/2 HP 115v____100.82____63987
Condenser motors
1/6 HP 220v enclosed____75.22____FSE1016SVI
1/4 HP 220v enclosed____75.15____FSE1026SVI
1/3 HP 220v enclosed____82.17____FSE1036SVI
1/2 HP 220v enclosed____100.82____FE1056SB
Specialty motors
ORM5458 Rheem multi amp___81.50
____98____125.67
___463___104.90
___510___41.85
___509___43.90___
EM550___22.00__
Brackets
A60055__18.95
KIT 200__14.07
A67804K_15.85
TFM-55__18.95
A67805K_13.27
A60007K_12.90
Jan 20, 2010 | Heating & Cooling
Need a ge motor 1/3 hp 1725 rpm for a toledo commercial slicer or why does motor will not start until you spin shaft?
check motors bearings for oil ports try to lube first before replacing-common motor -appliance parts-online parts-catalog(grainger)or other hvac-plumbing-heating stores
Nov 04, 2009 | Kitchen Appliances - Others
2002 buick regal blower motor trouble. voltage at motor is 4.29 ,that is the same at the fuse. I have replaced thebrlower resistor . and now have battery voltage at the connector for the blower. fan still...
The fan motor may need replaced. Over time with low voltage electric motors go bad just as with high voltage. More than likely it has burned out. You can try replacing the contacts in the motor, but I believe it is easier to replace it.
Oct 27, 2009 | 2002 Buick Regal
Interior heating/cooling fan not working
More that likely, it is the motor itself. The motors are easy to change
Sep 23, 2009 | 2001 Buick Regal
I?ve had many blower fan motor failures in such a short time?
This is Typical around this YEAR, if the Blower Resistor Is ok they should give you a Few Years service. The VOLTAGE READINGS Are GOOD that your Friend Checked. Be Sure the GROUNDS are RENEWED on these Vehicles as POOR GROUNDS are Pretty Typical for failure also around that Year
Sep 20, 2009 | 1995 Toyota T100 Xtracab
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
