Question about InFocus IN42 LCD Projector
Infocus IN42 projector just bought seems to be displaying in a green/yellow tint the coloring all the settings seem balanced, and changing them doesnt make it any better?what could be the problem and how could it be fixed?
5 Suggested Answers
SOURCE: Hitachi CP-S235 Data Projector - yellow tint to projected picture
Replaced cable and the problem was solved.
Posted on Feb 12, 2009
timothypeacy
  • 23 Answers
SOURCE: Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Posted on Jul 24, 2009
mastertech48
  • 149 Answers
SOURCE: Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Posted on Sep 08, 2009
Testimonial: "Thank you!"
  • 269 Answers
SOURCE: inFocus projector display has a blue color and
if these blemishes look like maybe its fuzz or something, you can remove the top cover and use compressed or canned air to blow out the area where you see 3 orange flat cables going under the main board into the lcd panels. blow it out good and be careful not to disconnect the cables as that can be a pain for the inexperienced. If this doesn't fix your problem, then I would say that the lcd panels have been burnt due to shutting the projector down improperly numerous times and no it is not worth repairing unless you get a known good light engine for less than the cost of a new projector plus labor-- unless you DYS.
Posted on Jun 11, 2010
Everything is yellow! It was working fine a week ago but when I went to do a presentation yestereday everything is yellow??? I tried adjusting the colors and I tried a second computer but yellow
hello,
what this indicate from the color display on the system mean that the display sensor (lens)in getting weak it need servicing or a replacement, to to this servicing you will have to unscrew (open) from the stroll then clean up the lens with little spirit solution on the surface with care allow the solution to dry up it self then reset the programming on it please while doing this you will have to be very careful with the wire connection around ,but if this fail then you will have to get a replacement on it
This are recommended fix is to replace the lens. You can generally find replacement parts at these websites:
www.projector.com
letsgodigital.org
comforu.com
technabob.com
techshout.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing a lens is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own
thank you and thanks for you sing fixya.
Jul 01, 2010 | InFocus X3 DLP Projector
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
I have a Infocus Screen Play 5000 bulb has 324 hours the picture is light green.
try reflashing the firmware, check your cables by wiggling the ends coming out of the projector and watch the picture for any changes, if it goes to normal at any time, your cables are just worn out. if that doesn't do the trick, maybe your lcd polarizers are burnt, i really need a better description of the picture.
Apr 01, 2010 | InFocus ScreenPlay 5000 Multimedia...
Yellow green display
you may have a bad cable. if it was an internal problem, the menu wouldn't be the correct color. you may also want to reset the settings to factory default, just to cover the resolution issue.
Jan 13, 2010 | InFocus LP70+ Multimedia Projector
The tint changes colors, green to red to blue, etc. while it is on. What's wrong?
you have a problem with the main controller board. unfortunately, there are no replacements from infocus. sorry.
but try to clean and resolder the edge connector (looks like silver fingers) contacts on the power supply where it plugs into the green plug on the main board. the main board may be getting fluctuations in voltage due to poor contacts.
Oct 14, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Jul 24, 2009 | Sanyo PLV 60HT Multimedia Projector
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
InFocus IN42 LCD Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
