Question about Canon Elura 65 Mini DV Digital Camcorder
Tape won't load. I just ejected it and it won't reload.
    Scholar:
  • 95 Answers
Try unplugging your camcorder from any type of power source. Leave it unplugged for about 10 minutes and try again (this will act like a reset button, which your camcorder doesn't seem to have one). If this does not work, you will need to have the camcorder repaired by an experience technician. There are lots of components inside the mechanism that could go bad or get damaged. Hope this helps you.
www.austintelstarservices.com
Posted on Sep 05, 2010
Ultrium 2 drive automatically ejects tape
Are you using the correct tape? If you try and use an LTO3 or LTO4 tape then it will just eject.
Does the drive make a clattering sound when first turned on and it goes through its POST ?
If the answer is YES then the drive has had a damaged tape loaded into it and the drive now needs repair.
Goto www.tape-drive-repair.com for repair or replacement options as these are quite inexpensive these days
Also try inspecting your media as per the guide here.
http://tape-drive-repair.com/tools-and-information/lto-media-inspection-guide/
If you find any damaged tapes then make sure to throw them away as should you reload these tapes they will go on to break your LTO drive again.
Sep 20, 2012 | HP StorageWorks Ultrium 460 () LTO 2 Tape...
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Vhs tape ejects when pressing record
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Feb 05, 2010 | LG Televison & Video
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 22, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Tape holder jammed
remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Jul 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Canon Elura 65 Mini DV Digital Camcorder Logo
118 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
