Question about Frigidaire GLWS1439F Top Load Washer
Frididair gallery series. would like to know how
Frididair gallery series. would like to know how to remove the agatator. i removed the softener disspencer,but i can`t get the cap off doses it pull off or doses it turn off
  • 262 Answers
There is one screw down the center of the adjitator, after removing the screw you pull straight up, sometimes brut force is needed.
Posted on Sep 05, 2010
Why won't our Frigidaire front load washer Gallery series empty the reservoir for the fabric softener?
The liquid fabric softener hoses often clog up due to the thicker nature of the fluid. They will need to be cleaned out. Sometimes a thin wire will work, but care must be taken not to puncture the walls of the hose. Once you have flow, clear the hose with hot water.
Nov 23, 2015 | Frigidaire Washing Machines
Frididaire gallery has power to lights but nothing runs
More than likely the compressor grounded out blowing the switch, which I've seen a few times dealing with that brand. The times that I've ran across this situation, the main control board inside the refrigerator had to be replaced as well because the compressor sent a surge up to that section severely burning the board.
Jun 21, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
Dec 07, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Would like to download owner;s guide for a frididaire gallery series slide-in stove Model # CGDS378DS1, serial No. 34315072
go to www.firgidaire.com click on the customer service tab at the top and select manuals you cah download it from there
May 13, 2008 | Kitchen Ranges
MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Apr 12, 2008 | Washing Machines
Frigidaire GLWS1439F Top Load Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
