Question about Microsoft Internet Explorer 8
I put a program i did not want in reclcle bin and in the middle of it i got a message saying debug or click ok i think. i clicked debug so computer froze. i had to restart computer then it came back on and my kittens wallpaper was gone and it was a blue screne and my icon were still there. i clicked on internet explorer and nothing happen.
  • 166 Answers
You have accidently deleted system files of internet explorer.
Try to reinstall or repair using the setup of Internet Explorer.
Restart and check whether your computer's desktop has been changed back to normal. If not follow the below steps.
Since your computer's desktop has been changed back, i doubt that you have also deleted main system files.Then in that case,
repair using Windows Installation Disk
Posted on Sep 05, 2010
Joint Strike Fighter crash
sorry to say bt i think that your operating system is not able to open taht game
Jul 29, 2013 | Eidos Interactive Jsf Joint Strike Fighter
Tip
How to View Windows Minidump Files
First of all, you need to configure Windows to save these important log files. Most of the time, this is already done automatically, however follow these steps to make sure these log files are being saved.
1) Click on Start
2) Right-click on My Computer
3) Click on Properties
4) In Windows XP , click on the Advanced tab. In Windows Vista , click on the Advanced System Systems option on the left side of the screen.
5) Under Startup and Recovery, Click on the Setting button
6) Under the System Failure section, you'll see the options for the memory dump file. Write an event to the system log should be checked along with Send an Administrative Alert. The debugging information should be set to the Small Memory dump (64K) and generally the Small Dump Directory is set to %SystemRoot%\Minidump. In most cases this is the C:\Windows\Minidump directory.
As far as the third check box is concerned, if this is checked the computer will automatically restart when a blue screen error message is encountered. So, if your computer is booting into Windows, then rebooting automatically most likely you are getting some sort of blue screen error message and its forcing the computer to restart. If you uncheck this box, then the message itself will appear so you can retrieve important details about the error.
Download and Installing the Debugging Tools to Read Minidump Files
In order to view the Minidump files, you have to download the following tools.
Debugging Tools for Windows including WinDbg
Although most of the time its not necessary, you can download the Symbol packages as well as the Debugging Tools so you can read the Minidump logs easier. Once you've downloaded the Debugging Tools for the correct version of Windows and installed them, open the WinDbg program by following these steps.
1) Click on Start
2) Click on All Programs
3) Click on Debugging Tools for Windows group
4) Click on WinDbg to open
The screen should look similar to the one below.
Deciphering the Minidump Files
In the WinDbg program, click on File, then click on Open Crash Dump
Browse to the following directory on your hard drive and open a minidump log. The drive letter will be whichever drive you installed Windows on. In most cases, this is drive C.
C:\Windows\Minidump
After you open a minidump file in WinDbg, scroll to the bottom of the file. You should see a line that says Probably caused by:, followed by a filename. This is the problem file. In my case the file was related to the ELock Program in the Acer Empowering Technology set of tools. I simply uninstalled this program from the computer and the blue screen and problem went away.
Probably caused by : eLock2FSCTLDriver.sys ( eLock2FSCTLDriver+11332 )
Although you may not recognize the file that is causing the problem, it definitely helps in tracking down a solution for the blue screen error message and resolving the issues.
on Jun 25, 2010 | Computers & Internet
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • Oct 25, 2011 | Microsoft Windows XP Professional
    Cant download skype, problem with toolbar, error 2738
    Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
    Log Name: Application
    Source: MsiInstaller
    Date: 23.09.2010 21:58:26
    Event ID: 1040
    Description:
    Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
    2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
    Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
    After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
    DEBUG: Error 2738: Could not access VBScript runtime for custom action
    3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
    The solution for a Windows Vista or Windows 7 32bit:
    - Click Start -> All Programs -> Accessories
    - Right click "Command Promt" and click on "Run as administrator"
    - Write "cd %windir%\system32" and hit Enter
    - Write "regsvr32.exe vbscript.dll" and hit Enter
    - You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
    - Click "OK"
    The solution for a Windows Vista or Windows 7 64bit:
    - Write "cd %windir%\syswow64" and hit Enter
    - Click "OK"
    4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
    If you still get the same Error than continue to step 5.
    5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
    The alternative solution for a Windows Vista or Windows 7 32bit is then:
    - Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
    - Click "OK"
    The alternative solution for a Windows Vista or Windows 7 64bit:
    - Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
    - Write "cd %windir%\ syswow64" and hit Enter
    - Click "OK"
    Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
    Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
    Vbscript.dll must get registered to solve the problem.
    Ref: http://community.spiceworks.com/how_to/show/1577
    Apr 25, 2011 | Computers & Internet
    Hi! i'm getting a message ATI video bio poller client: Ati2evxx.exe-Application Error, and in the message box it says the instruction at ''0x7c911129'' referenced memory at ''0x008c3005''. The memory could...
    Uninstall your Graphics Drivers and reinstall after a reboot. Also clean
    out your \Temp folders by deleting all files and sub-folders not currently
    in use at the end of the day. Then run Disk Cleanup.
    Also run your Windows Registry Cleaner. This will help speed up your PC.
    Schedule a Chkdsk /f and reboot to run.
    Run your Defragmentation program.
    Mar 30, 2010 | HP Compaq Business Desktop dx2200 - P4 524...
    C:\PROGRA~\MYWEBS~1\bar\1.bin\M#PLUGIN.DLL
    Click Start
    Click Settings
    Click Control Panel
    Click Add/Remove Programs
    Select 'MyWebs'
    Click 'Remove'
    When done, restart your computer.
    Oct 21, 2009 | Microsoft Computers & Internet
    After i install yahoo messenger this script shows up ..
    i cannot sign in to yahoo messenger. it keeps on saying "messenger encountered a connection problem. please check the network connection and then click "try again". (81003004
    Apr 25, 2009 | Yahoo Messenger
    PC Start up
    hi dear
    choose safe mode with pressing F5 button
    try to fix your start up program, uninstalling your relation software
    or try anti spy
    or hijack
    reset your computer
    and try to normal login
    oke
    Mar 27, 2008 | Computers & Internet
    Internet
    For Internet Explorer 5 and above, you can follow these directions to clear out temporary files and delete cookies.
    1) Open Internet Explorer and click on Tools
    2) Click on Internet Options
    3) On the General Tab, in the middle of the screen, click on Delete Files
    4) You may also want to check the box "Delete all offline content"
    5) Click on OK and wait for the hourglass icon to stop after it deletes the temporary internet files
    6) You can now click on Delete Cookies and click OK to delete cookies that websites have placed on your hard drive.
    To clear the Internet History in IE:
    3) On the General Tab, in the middle of the screen, click on Clear History
    4) Click OK
    To clean up other temporary files on your computer in Windows 98 or higher:
    1) Click Start, Programs (or All Programs), Accessories, System Tools, Disk Cleanup
    2) Choose the correct drive usually C:\
    3) Check the boxes in the list and delete the files
    Nov 13, 2007 | Toshiba Satellite A135-S2386 Notebook
    Open Questions:
    Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
    Jul 07, 2014 | Microsoft Internet Explorer 8
    See all Microsoft Internet Explorer 8 Questions
    Microsoft Internet Explorer 8 Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
