Question about GE WSXH208A Front Load Washer
The frabic softner dispensor is not releasing the softner in the washer.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Posted on Sep 05, 2010
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
Dec 08, 2016 | LG Washing Machines
Bosch Logixx 8 Fabric conditioner not releasing into wash cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Washing Machines
He3t washer frabic softner compartment isn't draining completly
Remove the drawer detergent dispenser. Then feel around in the front of the empty drawer tray for any missing detergent caps or chunks of anything. This can cause your issue - and can be an easy fix.
Aug 08, 2010 | Kenmore HE3T Washer
My he3t machine frabic softner compartment is not draing completly
remove the drawer detergent dispenser. Then feel around in the front of the empty drawer tray for any missing detergent caps or chunks of anything.
RTW434OSQO Is there a place to add softner
Actually no. The only thing you can add in your machine is soap and bleach. There is not a fabric softener dispensor in either the agitator or the chassis.
I am not endorsing this product only using it as an example but you can use one of these to automatically add fabric softener post 1st spin cycle:
http://www.downy.com/en-US/product/the-downy-ball.jspx
There are 2 or 3 different variations from several manufacturers out there.
Thanks for using FixYa.
Kelly
Apr 04, 2010 | Roper RTW4300SQ Top Load Washer
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Washing machine
hi if your softner dispensor is a removable compartment from the soap powder drawer ? then remove the dispensor and you will see the pipe with cap on top at rear ? pull this pipe off and ensure it is not blocked and that the cap is a firm fit on top? then ensure the short pipe that is part of dispensor tub is clear reassemble and refit try again ? these softner dispensor work by syphon effect IE when you top up to recommended level with softner in dispensor ? it remains untill wash is at softner rinse cycle then when water is entered into dispensor of softner and the level is raised to above the short pipe within compartment and the outer pipe with top on ? the syphon effect takes place and the softner+waterlevel is is syphoned int machine and dispensor is empty?? i hope you understand ? it is simple and works if you think of a toilet cistern how it syphons water for flush it is the same principle hope this helps
Oct 30, 2008 | LG Washing Machines
Softner wont go into the washing machine
removing the front plate won't help you, take the draw out. Get a long bag tie or inner core of any mains twin and earth cable and push it into the holes in the top of the dispensor, move it about in/out etc, changing the holes as required, this normally works, if it doesn't the dispensor lid is available as a seperate part and is quite easy to change.
Jul 06, 2008 | Zanussi FJS1225W Front Load Washer
Frabic Softner Dispenser
the water valve for the softner is not opening. depending on the model, you can put unit in a service mode. this will let you cycle through the valves.
May 22, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
My Axxis wfr 2460 is not releasing the fabric softner from the drawer
You could try a tooth-brush. And after you fill your quantity of softener, top it with water till the exit level of the compartment. You could also check whether water actually pours into the compartment during the final rinsing of the clothes; in this case you should check the inlet pipe screens of your inlet pipe into the machine; which can be done without opening up the machine.
Nov 30, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
GE WSXH208A Front Load Washer Logo
348 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
