Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Where is a cancel or clear button? I have the button pressed for regular wash and then I hit start, I then realized I wanted to do quick wash instead but I cant find the cancel or clear button.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
If your machine is indeed an SHU66 series machine it should resemble the image here, with perhaps a different color...
If you notice the two buttons pressed together should cancel the cycle and force a drain/end cycle.
For future reference, if you'd like to simply select another cycle after one has already been started, press the button applicable twice quickly and it will switch to that cycle.
Hope this answers your question. Let me know if your require further assistance.
Thanks for choosing FixYa, good luck.
Regards,
Macmarkus :)
Posted on Sep 05, 2010
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Casio te 2400
Turn key to Program enter 4 subtotal (may need to put in a clerk #)
Enter 236 press Cancel Button hit subtotal to exit.
Nov 06, 2013 | Retail Supplies
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Can not clear the FL code. Want to fix machine don't know where to start. Diagrams would be helpful.
This is a flood condition.
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
If it continues, simply replace the over fill switch.
May 28, 2009 | Whirlpool Washing Machines
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Hit wrong button
press and hold start/cancel button for 5 seconds and machine should reset
Jul 14, 2008 | Frigidaire Washing Machines
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
354 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
