Question about Samsung PN50B860 Plasma TV
We have a 50" Sony Plasma TV (PN50B860) that now has 2-3 inch-wide vertical lines (about 4 lines) on the left hand side of the screen that come and go. What is causing this?
  • 1 more comment
  • sbflinn Sep 05, 2010
    It only started doing this recently.
    Yes it does the lines with all sources, dvd, xbox, cable. Each source is directly plugged into the tv, some using hdmi others using coax or av cables.
  • Samsung Master
  • 11,800 Answers
These lines are caused by a failure in the buffer memory of the image processor. The entire mainboard will gonna have to be replaced and it will be expensive.
Posted on Sep 05, 2010
  • 2,335 Answers
I can help you with your Plasma TV display problem.
Two reasons the integrity of your display of your signal may be compromised include:
  1. A signal problem. This is interference on your signal path. More likely on older sets not using hdmi or component cabling, but still, check the whole path of your video signal from the wall to your sat/cbl box, av receiver etc to the TV. Many fancy HD installations still have a weak coax link. Make sure all cables are not damaged in any way, the contacts are good, & they are not lying across power cabling or wrapping around power cabling. This is not the most likely cause of your problem, but is a possible solution in some cases of your symptoms & basically free to try (so worth doing first, rather than after, replacing parts on your TV).
  2. Bad input or processing circuitry inside your TV. Wide vertical lines showing up on your display are indicative of failed/failing display circuitry, or failure between the signal going into the TV and getting to the display circuitry. On a plasma TV, after the signal gets to the processors, the picture is split in half then processed separately and then recombined. A very common problem for plasma tv's is a horizontal line or lines in the middle of the screen, caused by a failure of the processing board that is responsible for coordinating top and bottom display. Your case involves a vertical noise line or lines, which does rule that particular board out - the problem is before that stage. Unfortunately, if your can't find a problem and easily solve it in your signal path, the next stage is returning the TV for IC troubleshooting and servicing.
One relevant thing you didn't mention in your post is whether this display problem occurs regardless of input source. If the problem occurs with DVDs as much as cable/sat then the problem can only be the TV (or av receiver of all sources lead there first.) If it never occurs through DVD then the cable/sat box is in question as well as the TV.
Similarly, If all sources DO go to an AV receiver before the TV, then the fault could be in the AV receiver. I myself have returned a Harmon Kardon AV receiver after 6 months, when its HDMI circuitry failed. In my case I lost all video function, but be sure that failing circuitry will cause intermittent video interference such as in your case as well.
To thoroughly troubleshoot your setup yourself before calling in the techs, you nee to simplify your signal path to the TV to confirm it is the weakest link: unplug everything, plug the TV directly into your video source (DVD for ex). Play it until you see the lines. Plug it directly into an antenna or cable (no box). Play it until your see the lines. Now you know it's the tv. If you had fresh cables with no power interference issues and good connections, you now know it is the TV for certain.
I hope that helps
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. These kind of issues in Plasma TVs are caused by overheating. To check what is bad, you'll have to open the back of the unit and check for any bulged/bad capacitors on the Y-Sus board along with the control board. As the sound is working fine so I dont think this is the power supply board which is causing this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Sep 05, 2010
    I understand, have you checked the Y board
Fix vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
Fix samsung plasma vertical black bar
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Samsung PN50B860 Plasma TV Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
