Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Encryption failing hi, i have set my fix ip,and did the wizard for secure my wireless. unfotionatly, on the encryption, he don t go further. i mean; i have set my wep on enabled, bytes 64, keytype = ASCII and filled in a 5 digit key. i press on next, and then he won t go any further ! my acces point is a d-link -2000ap+ can anybody help me threw this/?? thx
  • 86 Answers
Configure SSID in you wireless router,
it is used to secure your inetrnet connection & wireless device,
1. Go to IE page type the router ip &login to the router, confiuration u can See the SSID, there u mention the password to communicate the wireless to PC.
Posted on May 18, 2008
I forgot my WEP key for my ps3
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Mar 18, 2012 | Linksys Computers & Internet
How can i make the password ?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 26, 2011 | Computers & Internet
Helllo, Just purchase the D-link Air plus Xtreme G DWL-2100AP Wireless Access Point but I cannot access to put my username/password. I connected it directly to the ethernet from the wall but I can...
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the access point (192.168.0.50).
Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK.
Step 3 Click on the Advanced tab and then click Encryption on the left side. Select the Wireless Band (DWL-7100AP only).
Step 4 Click the radio button next to Shared Key and then click Enabled next to Encryption. Make sure your other wireless devices are set to Shared Key.
Step 5 Next to Key Type, select HEX or ASCII. You will need to use the same key on all your wireless devices.
· HEX - use 0-9 and A-F only.
· ASCII - All numbers and letters.
Step 6 Next to Key Size, select the level of encryption (64, 128, or 152-bit).
Step 7 You can enter up to 4 different keys. Select the key you want to use from the Valid Key drop-down.
Step 8 Enter your encryption key. You make this up yourself. If you selected HEX, then enter a key made up of a combination of numbers (0-9) and letters (A-F). For example - A4572BCC19 (HEX).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | D-Link AirPlus Xtreme G Wireless Access...
I DON T KNOW HOW TO CHANGE THE SETTINGS ON MY ROUTER SO THAT IT CAN CONNECT WITH MY WII. THE ROUTER AND THE WII ARE COMPATIBLE BUT IT SAYS TO CHANGE THE ROUTER FROM 6 TO EITHER 1 OR 11 BUT HOW DO U DO...
Go to your router's Web Utility, if possible through a computer connected to the router by cable (because you'll loose access to the router once you change its encryption rules). If you haven't changed the access parameters, the default IP address is 192.168.1.1, with 'User Name' left blank, and 'Password' set to 'admin'. In the 'Wireless' tab. I supponse you already have encryption definitions there. Try to set your 'Security Mode' to 'WPA Personal' and 'Algorithm' to 'TKIP'. Chose any 'WPA Shared Key' you want (from 8 to 63 characteers), and set the 'Group Key Renewal' parameter to 0 (zero, i.e. no key renewal, at all). Save your settings.
You see, my router is not Linksys, but in essence, the encryption parameters are quite alike, and this is how I managed to provide internet to my son's Wii console.
Hope it works for you.
Regards, Carlos
May 27, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I security enabled my belkin eb547d but when i put in the password it tells me I have to code it as wep or wpa
The passphrase is a method of setting up the encryption setting in the wireless router. Go into the router configuration and then into the wireless settings. I suggest you use WPA encryption as WEP is older and weaker encrypyion method.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 15, 2009 | Belkin Wireless-N Wireless Router with...
Homegroup problems with wndr 3700
The wireless router needs the wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
Nov 14, 2009 | NetGear RangeMax Dual-Band Wireless-N...
I just set up a netgear router and a lynksys expander. All my laptops work, but iphone & itouch will not. Seems as though the password has changed. Can this happen? How can I find the password? When I...
If you did not configure the Netgear wireless router and changed the default settings and the default password password, then your wireless system is open to anyone hacking into your system and change your wireless router's settings and they can hack into your computers and your Internet connection. The Linksys expander will increase the wireless range to give a wider coverage to your router.
I suggest you reset the Netgear back to the factory defaults (press the pinhole button on the back of the Netgear router until the LEDs flash then release this button,
The configure the Netgear as follows :-
Nov 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Why won't my ps3 connect to my wireless router? An IP address is needed which it will not find, only on wired connection will it connect!?
Disconnect the LAN cable from the PS3.
The PS3 needs to be configured as follows :-
Select Network Settings - Easy - Wireless - Scan, select your wireless router, select your SSID, if it isn't displayed the type it in, select security settings, enter your router's encryption settings
Your router will issue an IP address to the PS3 and you will able to access the Internet wirelessly.
Jul 26, 2009 | Computers & Internet
How to make my wireless secured? I have a D-Link AirPlus Xtreme G DWL-2100AP
acess your router http://192.168.0.1
or http://192.168.1.1
then user is admin
passowr dis bleank or admin
then selcet setup of nternet type is with static ip set ip and gateway.
also set security encryption key.
also enable advanced security.
then allow mec adreses of which u want to give internet.
Nov 29, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
(Work this one out) My access point works but I have never been able to set security settings on interrogate it.
try typing 192.168.1.1 in your internet browser..the login and password are usually admin  and admin respectively.you can then configure further settings without using any cd etc.hope it helps!
Oct 22, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
