Question about Vacuums
Bissell - Model 1697 - Powersteamer Pro - Carpet Cleaner I took the unit apart to replace some broken pieces and I can not seat the bottom to the top without properly engaging the soap/water mixer. What is the proper assembly procedure. What is the orientation of the water/soap mix valve when I seat the top to the bottom? The soap/water mix valve needs to engage the knob screw threads but this assembly is a blind operation. Do I turn to the soap/water mix knob to water only then seat the bottom and top together?
  • 4 more comments
  • dlebioda Sep 05, 2010
    The is a carpet cleaner.
    Bissel - Powersteamer Pro Model 1697
    There is a soap / water mix knob on the right top side of the unit.
    When assembling the top to the bottom what position should the soap /water mix knob be in so the knob engeges the mix valve?
    To disassemble the top from bottom I removed 4 screws around the bladder (water container)
    the top front was hooked onto the bottom at the front of the machine.
    After you assemble the top the bottom how do you tell if the soap / water mix knob is engaged with water / soap valve?
    When I rotate the water / soap knob, the top seems to push away from the bottom when I am watching the side of the rug cleaner.
    Incorrect assebly guide. Need assembly guide for Bissell Powersteamer Pro Model 1697
    guru_fixya,
    Thank you very much for the parts diagram. The first parts diagram (the diagram with 75 pieces) that you sent me is the Bissell model 1697 PowerSteamerPro that I have. It helps a little but now I can use the part names on the diagram to explain my problem.
    The Automix knob was broken and the right and left elevator lifter were broken. I purchased new parts and am trying to reassemble the rug cleaner.
    Here is how I am assembling the machine.
    - Insert Automix knob (30) into Main Housing (31)
    - Automix Piston (42) is seated in the Automix Assembly.
    - I rotate the Automix Piston (42) counter-clockwise and insure that it is seated in the Automix assembly.
    - Mate the main housing (31) to the base assembly (40) by clipping the front of the main housing (31) over the front of the base assembly (40). There are no screws in the front and the base assembly just has a small catch that locks onto the base assembly.
    - Hold the rear of the main housing (31) and the base assembly (40) together. I didn't put the four screws in yet.
    - Rotate Automix knob (30). I watch where the main housing (31) and the base assembly (40) meet and notice that when I rotate the Automix knob (30) the Main housing seems to be pushing away from base assembly.
    How do I insure that the Automix knob (30) engages the Automix piston (42)?
    The assembly is a blind operation and I can't seen the parts engage.
    Dan
    - Do NOT Insert Automix knob (30) into Main Housing (31).
    - I rotate the Automix Piston (42) so it lines upwith the details of the Main Housing (31). You need to look through the hole where the Automix knob goes.
    - Make sure that the Automix Piston (42) slides uo and down easily. I had to lubricate with petrolem jelly.
    - Screw the rear of the main housing (31) and the base assembly (40) together using four screws.
    - Look through the Automix knob hole in the top of the main housing to insure that the Automix piston isn't trap and is lined up with the details in main housing (31).
    This is wher I am at. Should I
    - Now fully seat (push down) the Automix piston (31) into the Automix assembly then screw in the Automix knob (30)?
    Dan
    I think I figured it out. Could you please confirm?
    This is the earlier comment just formatted so it is readiable.
    - Make sure that the Automix Piston (42) slides up and down easily. I had to lubricate with petrolem jelly.
    This is where I am at.
    Should I - Now fully seat (push down or raise) the Automix piston (31) into the Automix assembly then screw in the Automix knob (30)?
    I just don't want to break the auto mix knob since this is one of the pieces I am replacing.
    Dan
    Yes....the diagram helped me describe the problem everyone knew what I was talking about. I used the part terminology of the rug cleaner in the diagram. The Automix piston must be in the LOWERED postion not the raised position. Then you screw on the Automix knob.
    Machine is now repaired.
  • 944 Answers
http://dl.owneriq.net/7/7e477b7e-4440-49cf-a219-b68d301549e3.pdf
This diagram will help you see the diagram plus the part assembly no and place it accordingly.I have also given link for Bissell - Model 1697 so you can use it more trouble shooting and where to assemble the parts.
01. Upper Handle Assembly - Slate Green **FNLA
01. Handle Assembly - Mean Green **FNLA
02. Spring - Push Rod 2108422
03. Push Rod with Spring 2147511
04. Trigger - Grey 2139168
05. Handle Assembly 2144406
07. Valve Assembly 2109592
09. Wire Harness 2104446
10. Lower Handle Back - Mean Green **FNLA
11. Handle Bushing **FNLA
12. Switch - Power 2108827
13. Cord 2102883
14. Tool Caddy 2146752
15. Cord Wrap 2131154
18. Axle 2100170
19. E-Ring 2106215
20. Wheel 2139754
21. Extruded Gasket - .136"X32" 2103418
22. Window Gasket 2104052
23. SmartMix® Bottle (Includes Cap) 2101785
24. SmartMix® Cap Assembly 2101795
25. Autoload Gasket 2036679
26. Diverter - Grey 2136988
27. Flow Indicator Assembly 5556503
28. Diverter Gasket 2114054
29. Diverter Knob Assembly - Grey 2145170
30. AutoMix Knob - Grey 2105108
31. Main Housing - Mean Green **FNLA
31. Main Housing - Slate Green 2145017
32. Flow Indicator Base 2100489
33. Floor Nozzle Window 2149871
34. Spray Tip (2 pk) 2106107
35. Connector T 2102602
36. Arm Retainer - RT & LT 5559113
37. Brush / Pivot Arm Assembly - 4row 2101157
38. Brush Belt 150621
39. Flow Indicator O-Ring for Powersteamer® Series 2106214
40. Base Assembly - Non-ClearView with 4 Row Brush **FNLA
41. AutoMix Assembly 2100107
42. AutoMix Piston 2108722
43. Motor Duct - Short **FNLA
44. Gasket - Short Duct 2104050
45. Belt Access Door 2132992
46. Motor Cover 2132984
47. Inner Motor Gasket 2104056
48. Motor Intake Gasket 2104051
49. Vacuum Motor 175972
50. Detent Lever 5559102
51. Elevator Lever with Springs LT & RT 2000010
52. Pump 2107181
53. Pump Belt 2150628
54. AutoLoad Receiver 2140710
55. Upholstery Hose Assembly - 8' 2153163
56. Tank-in-Tank Assembly 159043
57. Tank Lid Assembly 154439
58. Tank Handle 2034435
59. Lint Screen 2133501
60. Baffle & Bladder Assembly **FNLA
61. Baffle with Float 2130213
62. Float Assembly 2140325
63. Bladder 2100315
64. Bottom Tank Assembly 159041
65. Screw #6 x 3/4" - 6pk 2807075
66. Auto Load Assembly 2107041
67. Autoload Gasket 2036679
68. 3" Tough Stain Tool Assembly 2159155
70. 4" Upholstery Tool 2036653
71. Brush - Upholstery Tool - 4" 2030966
72. Turbo Brush 2036652
73. Crevice Tool 2036655
74. Pre-Treat Wand 2149142
75. Bare Floor Tool 2149131
Posted on Sep 05, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 05, 2010
    01 2109201 UPH TOOL 4" COMP BLK REPL
    02 2030961 WINDOW FOR 4" TOOL LGCMREPL
    03 6030966 BRUSH-REMOVABLE, 4" TOOL REPL
    04 2159155 TUFF STAIN TOOL 3" ASSEM REPL
    05 2149155 BRUSH FOR 3" TOOL. REPL
    06 2039850 WINDOW 3" TUFF-STAIN REPL
    07 2153163 HOSE/DUCT/GRIP ASSY 8FT REPL
    08 0154439 TANK LID W/SCN&GSKT&HAND 1698
    09 2034435 HANDLE TANK REPL
    10 0144401 HANDLE UPPER ASSY BK W/O LABEL
    11 2139168 TRIGGER 1697 REPL
    12 0147511 PUSH ROD W/SPRING 1698
    13 2108422 SPRING PUSH ROD REPL
    14 2109592 VALVE ASSM TRIGGER 1697 REPL
    15 2144406 HANDLE UPPER ASSM BK W/O DEC
    16 2140325 FLOAT ASSEMBLY TANK REPL
    17 2130213 BAFFLE & FLOAT ASSY REPL
    17 2140213 BAFFLE & BLADDER ASSM REPL
    18 2100315 BLADDER 1697 REPL
    19 0159041 TANK BOTTOM W/AUTOLOAD RPL1698
    20 0141782 DRAIN CAP ASSEMBLY 1697
    21 2109148 CREVICE TOOL REPL
    22 2104052 SEAL TANK INTERFACE 1697 REPL
    23 0149865 WINDOW NOZZLE W/HOOK&DECO NEW
    24 2136988 DIVERTER BLACK REPL
    25 2145170 DIVERTER ASSEM REPL
    26 2807075 SCREW #6 1/2 PHL/SLT REPL
    29 2807030 SCREW #8PLAS X 3/4 REPL
    30 2104054 GASKET DIVERTER REPL
    31 0154909 MAIN HSG ASSY COMP BLK1698REPL
    32 2101785 BOTTLE ASSEMBLY REPL
    33 2101795 CAP DETERGENT REPL
    34 2104050 GASKET-SHORT DUCT REPL
    35 2103161 DUCT-SHORT, MOTOR
    36 2104051 GASKET MTR INTAKE REPL
    37 0132907 COVER MOTOR W/LT EXT. NO ASSY.
    38 2107041 AUTO LOAD ASSMEMBLY REPL
    39 2132993 COVER BELT BLACK REPL
    40 2104053 O RIN0-LONG DUCT 1697 REPL
    41 2103160 DUCT-LONG, UPHOLSTERY REPL
    42 2104056 GASKET MOTOR INNER REPL
    43 0175972 MOTOR 1697 W/BOX
    44 2107181 PUMP,W/LRG PULLEY 1699 REPL
    45 0150624 BELT,PUMP 1PACK1699 W/INST
    45 2100622 BELT,PUMP 1PACK1699 W/INST
    46 0150621 BELT-BRUSH 1-PK W/INS 1698
    46 2100621 BELT BRUSH 1-PACK REPL
    47 2158001 T ASSM ODD BARB REPL
    48 0140710 AUTOLOAD CAP & ASSY. 1697
    49 5559102 PEDAL-HANDLE RELEASE
    50 2100170 AXLE WHEEL REPL
    51 2139754 WHEEL 1697 REPL
    52 0140454 BASE-HSG ASSY ROTARY BRUSH
    53 2100107 AUTOMIX ASSY W/O WELD CAP REPL
    54 2108451 SQUEEGEE BARE FL TOOL REPL
    54 2149131 BARE FLOOR ATTACH ASSY REPL
    55 5559121 PIVOT ARM RIGHT ASSY. 1697
    56 2107370 ARM RETAINER RT 1697 REPL
    57 2000010 LEVER ELEVATOR LEFT&RIGHT REPL
    58 2106107 SPRAY TIP 1699 REPL
    59 2102602 CONNECTOR T 1697 REPL
    60 2104054 GASKET DIVERTER REPL
    60 5559128 ARM RETAINER LEFT 1697
    61 2000010 LEVER ELEVATOR LEFT&RIGHT REPL
    62 2108420 SPRING ELEVATOR LEVER REPL
    63 5559118 PIVOT ARM LEFT ASSY - 1697
    64 2101174 DOWEL TUFTED BRUSH NEW REPL
    65 2108451 SQUEEGEE BARE FL TOOL REPL
    66 0104451 HARNESS WIRE 1698 & 16981
    66 2104446 HARNESS W/INS TERMINALS
    67 2146752 HOSE RACK & CORD WRAP REPL
    68 2104501 HEATER 1698 REPL
    70 0144432 HANDLE LWR BK BLK W/SWITCHES
    71 2105603 LIGHT IND REPL
    72 0144420 HNDL LWR FRNT ASSY BK NEW HXFR
    73 2106215 E RING WHEEL AXLE REPL
    74 2101256 BUSHING HANDLE 1697 REPL
    75 2101197 TUBRO BRUSH CLEAR BLUE REPL
    76 2108550 STABILIZER HEATER 1697 REPL
    77 2102818 CORSET W/HEYCO 30" 1698 REPL
    77 2102825 CORD 30" W/ HEYCO INS TERM REP
    79 2101651 CAP FLOW IND REPL REPL
    80 2107635 SPINNER FLOW IND REPL
    81 2103510 FILTER FLOW IND 1-PK REPL
    82 2100489 BASE FLOW IND O RING REPL
    83 0131154 CORD WRAP
    84 2108722 PISTON AUTOMIX REPL
    The procedure you are followed is correct.Yes raise the Automix piston into the Automix assembly then screw in the Automix knob.if it is correctly placed then it will get screwed properly.
    Genius:
  • 1,478 Answers
I will advice you check the information on how to assemble the seat bottom and other parts from this link, http://middleeasten.bissell.com/images/UserGuides/3522_105.pdf
It shows the images and procedure on how to go about it.
Take care.
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
How to operate a bissell powersteamer pro carpet cleaner
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
May 28, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Not working
The bissell shampooers use belts t run the pump and the beater bar. if the master beltbroke which is the one that controls the pump and beater bar then yes the machine will not dispense water or turn the beater bar. it will have to be replaced *the belt that is*
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
1,343 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
