Question about RTO Chrome YL88 Keyless Electronic Digital Door Lock
Have yl-88 keyless lock. It does not light. I replaced the batters, still not response. Can you help?
  • hg3937 Sep 05, 2010
    I tried it, It did not work.
  • 12,061 Answers
Www.bulldogsecurity.com/pdf/Model1402.pdf
www.blackwidowsecurity.com/installPDF/BW853%20Install.pdf
Hi I have found your user & install manuals for you, Above, it shows you in there how to enter the master code to reset the unit. Try that, and then set it up again. These are fairly reliable, but the electronics do fail, this is usually bad soldering, and often a quick "lick with an iron" will put things right.
Posted on Sep 12, 2010
  • 10,865 Answers
Hello. Remove the battery and test it to make sure it is good. Also get a spray can of electronic contact cleaner at any radio shack or auto parts store and spray the battery contacts in the lock to remove any weather caused corrosion. Then install good batteries paying close attention to the polarity. [+ and -]
J.
Posted on Sep 05, 2010
  • Joe Hogan Sep 06, 2010
    Hello again. Since the steps above did not solve your problem, I suspect that the light bulb in this device is worn out. The bulb can be replaced. Just take the entire lock set to your local lock smith shop. J.
  • Ron Nietz
    Ron Nietz Jan 18, 2011
    I have the same problem with my YL-88. No power, no beep and no light with either the internal batteries (new) or the backup power. Would a blown bulb stop it from workink as you said have a new bulb installed? I see they make a newer model (YL-99). And the 88 is no longer available. Maybe they did have a problem with it.
How do I set up the id cards for a YL-99 Taft electronic code lock?
I have no idea but someone please tell us because we'd like to know also
Oct 18, 2014 | Locks & Locksmithing
My haier remote model # YL-M05, got locked and I dont know how to unlock that please help me.....
use a paper clip to poke into the reset hole,the unlock button is used to lok the buttons,press it once for lock again for unlock
Sep 03, 2013 | Haier YL-M05 Remote Control AC-5620-35
How do I get a manual for YL88 electronic lock
Okay Guyz n' Galz...Finally I solved this by lot of iterations. I have YL-88, YL-68 and D77 Digital locks. They are all made by Yili from China with buttons placed circularly. Warning, to reset it might not work on button placed in square pattern (YL-99).
Default master code is 0123# all the locks mentioned above.
Now to reset the master code, press and hold the reset button(red) for 2-5 secs on the battery pack, and remove one battery. Release reset button. Give 5 to 10 secs. Then press and hold reset button first, put back the battery into it.
Now the lock is reset to factory default. i.e., 0123#.
Warning: Make sure the default works before you close the door and lock.
Now to apply new master code: Enter default 0123# and wait till the sound is gone and the light is still lit. Start your new code starting with '0' and end with * key (not the # key). It will beep twice. Your new master code is ready to use. Now if it does not beep twice. Try from the begining with default code.
Enjoy
Your'
Problem solver!
Jan 04, 2012 | RTO Chrome YL88 Keyless Electronic Digital...
How to reset codes on a yl88 keyless electronic digital door lock lost the manual and cannot work it have no emergency module
Enjoy
Your'
Problem solver!
Oct 02, 2011 | RTO Chrome YL88 Keyless Electronic Digital...
How to program the keyless remote for a Hyundai Entourage, after replacing the batter. After I replaced the battery and press the buttons, it lights up but nothing happens.
You sure it's the original Keyless Remote (key fob) programmed for the vehicle? If so, you, yourself, cannot reprogram it.. you have to take the vehicle into an authorized Hyundai Dealership to have the remote programmed for the vehicle or have the problem diagnosed... sorry!
Nov 04, 2009 | 2007 Hyundai Entourage Limited Minivan
2000chevy malibu keyless entry problem need help
1. Close the vehicle doors.
2. Turn ignition to the ON position then OFF.
3. Remove key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position
until step 8.
5. Insert the ignition key into the ignition lock cylinder and remove the key.
(Do not turn the ignition key in the lock cylinder)
6. Insert the ignition key into the ignition lock cylinder and remove the key.
7. Insert the ignition key into the ignition lock cylinder.
Leave key in the ignition cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order
to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless remote and
hold unitl the vehicle beeps twice to verify that the keyless remote has been
successfully programmed. This may take approximately 15 seconds.
10. Perform the previous step (9) to program up to four keyless remotesm, including
any old ones.
11. Remove the ignition key to exit Program Mode.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | 2000 Chevrolet Malibu
Keyless entry stopped working on 05 cobalt now i have to unlock door with the key and when i do that the alarm goes off. Help
Lock all the doors from the inside (with all the doors closed), unlock your driver's door by manually lifting the lock, then press it back down after you are out - this will prevent the alarm from sounding when you use the key to unlock the door.
Aug 02, 2008 | 2007 Chevrolet Cobalt Coupe
RTO Chrome YL88 Keyless Electronic Digital Door Lock Logo
230 people viewed this question
Top RTO Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a RTO Lock and Locksmithing Expert? Answer questions, earn points and help others
