Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Bottom draw used infrequently - coonot use comes up with code LP
  • Fisher and P... Master
  • 3,247 Answers
I am assuming the top drawer is working ok.
The code LP (meaning low pressure) is possibly linked to the inlet water not coming in at the correct pressure.
If this is happening with the bottom drawer only, then the likely cause is a kink or cracked inlet water connection to the drawer. YOU will have to turn the power and water connection off and pull the drawer out to inspect.
Posted on Sep 13, 2010
300ma parasitic draw from CTSY LP; 1999 GM 4.3L! What is this or where could it be?
Sounds like something was using too much power. The 15amp fuse could be a fire hazard if you leave it in.
The draw could be a short in one of the switches. Its possible that circuit is providing power to the radio memory too.
Feb 26, 2015 | Cars & Trucks
Rapid battery discharge
The raido, lp alarm and co2 alarm all use battery even when "not in use" Also the AC, Furnace and Refrigerator all use 12v power. Make sure all are turned off. Next, you need to perform an amp draw and a battery load test. You may have either a bad battery or the converter is acting up and creating a draw.
Feb 27, 2014 | Heartland 2013 Wilderness WD 2650BH
I have Minolta Copier CSPRO 4000; it has error Code: c0372 please help
The bottom paper draw and duplex section have each a plug you plug into the copier in the rear. you mite want to check them for loose connections or the connectors themselves the code is stating that copier can not talk with bottom draws or the duplex section which makes your second side on a single paper. Open close front door to reset and could reset the machine power it off disconnect bottom draws and duplexer then just use the copier that way.
Jan 10, 2013 | Minolta EP4000/5000 CS/PRO Copier
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
WE HAVE A KENMORE GAS RANGE ABOUT 10 YEARS OLD.WHEN WE TRY TO USE THE OVEN IT WILL LIGHT BUT NOT COME UP TO TEMP.BROILER WORKS FINE.ON LP GAS.NO IDEA WHERE TO START.DON'T KNOW IF IT IS BURNER OR WHAT.COULD...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 09, 2010 | Kenmore Kitchen Ranges
U 3 in red on fisher paykel single draw dishwasher
These are the cause of this fault
Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
Mar 03, 2009 | Fisher and Paykel Active Smart® E522BR...
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
53 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
