Question about GPS
I lost my immobiliser key to my pajero and would liike to deactivate the immobiliser all together or get a nother key to replace the one that I lost.
  • darrell_cren Sep 05, 2010
    I can't really take the truck to a manufactor or dealer because I am on Ascenion Iland and would like to know if there is a way of contacting a manufactor or something that would get me a new immobiliser key to buy.
    Genius:
  • 1,035 Answers
What model/year Pajero? Basically, are you removing an aftermarket immobiliser or circumventing a built-in unit? If its the former, then typically these immobilisers work by interrupting the +12v supply to either fuel solenoid cutoff, ignition (petrol), fuel pump (petrol?). Most immobilisers will have 2 'channels' which they can interrupt, so that even by reconnecting one, the other will still be immobilised offering a level of protection. If the immobiliser is properly installed, the wires going to it will all be black (they have little tags, which are removed as the last task of installation)) and it will have 2 earths - meaning that if any one wire is cut on it, it will sense this.
So basically, you need to look up the location and colour codes of the wires for the fuel pump relay, ignition or fuel cutoff solenoid, and rejoin these.
Posted on Sep 05, 2010
    Brigadier General:
  • 3,917 Answers
2001 chevy cavalier lost key can I replace the ignition switch without a key?
the original key is coded to your car.
So changing the barrel to have a new key wont help and ill tell you why.
Inside the original key is a transponder chip that is programmed to the cars immobiliser unit.
Attached to the ignition barrel is whats called a reader coil and its job is to read the keys chip when inserted in the barrel to deactivate the immobiliser so that the car will start.
What you need to do is contact a good knowlegable locksmith to provide a new key and code it to your car
Nov 03, 2016 | Cars & Trucks
Why would I have no power at all when the key is turned on after replacing the battery with a new one?
The key and immobiliser/security system have lost pairing. May need re-programming to pair together again. Or it is possible the battery you have just put in is a duff one.
Sep 02, 2014 | Motorcycles
Immobiliser won't work.
If someone reached through the window to open the car without using the key, you have to lock it up and open it again with the key and a fully charged battery for it to start.
Mar 24, 2014 | 1990 Nissan Pulsar
A small nob which deactivates the immobiliser in my Daewoo 2001 nubira has broken in to poeces. Can some one help me start the car by bypassing the immobiliser?
if that knob has 2 wires going to it u can join the 2 wires together or touch them together to deactivate immobiliser , the knob is a switch that either connects the 2 wires or disconnects them when pushed ,if there are more than 2 wires i would need to know the colours and how many there are
Jan 15, 2014 | 2002 Daewoo Lanos
How to start toyota camry without the key
you most likely wont start it without a key, if it has a factory immobiliser the key has a transducer in the base of it that activates & deactivated the immobiliser when it is put in or pulled out of the ignition switch.......hope this helps.....cheers
Aug 07, 2010 | 2005 Toyota Camry Solara
Immobilizer light
When you turn the key in the ignition, the ECU will ask the immobilizer if it can start thecar. If the signal is not sending then immobilizer error will show.There is a way to deactivate the immobilizer. The procedure is as follows:-- To deactivate the immobiliser just turn the ignition 3 times on and off and the immobiliser will deactivate .But if still the same problem then this could be the immobiliser read coil around the ignition switch or its a flat battery problem. Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | 2009 Toyota Camry Hybrid
My battery died on my 2003 tiburon and i tried to boost it and the lights start blinking and the siren goes off but the car won't start
Hello there,
Your Immobiliser has activated the alarm, you must deactivate the immobiliser to deactivate the alarm. go into the car (even if siren is wailing and your neighbours are nosy) close the door and put key in the ignition, turn key to ACC position. Hold down unlock button till you see indicators flash once. Remove keys and get out of the vehicle. Try unlocking and locking. This should be reset.
Cheers Buckaroo,
Chris.
Apr 19, 2010 | 2003 Hyundai Tiburon
I loose keys of my Pajero which have a engine immobilizer system I buy new keys but its not respondind what can i dou?
you will probably have to take it back to mitsubishi to reset the code on the immobiliser ecu
Oct 29, 2009 | 1999 Mitsubishi Montero
I own a 1992 pajero, the battery in my keypad went flat and since changing it i haven't been able to start my car as the immobiliser doesn't recongise it any more, any ideas on how i can fix this??
hi not sure if this will work on pajero but worth a try ?? insert key and turn ign on only ! then press key fob lock button for 10 seconds then turn off ign and remove key wait 10 seconds thenpress lock and and unlock on remote fob if this works ? the immobiliser will have reset hopefully ? and car will start ? will keep fingers crossed for you best of luck!
Nov 05, 2008 | Mitsubishi Passenger Cars & Trucks
Cobra immobiliser key
After ages searching finally found this on the Cobra site.... A8510 KEY PROGRAMING Ensure the immobiliser is disarmed :- 1) Switch the ignition ON and OFF three times then back to the ON position within seven seconds. 2) The LED on the dashboard will light up signaling the unit is in programming mode. 3) Touch an already programmed key onto receptical, the LED will extinguish for one second 4) Repeat step 3 for all other keys (Max of 4 touch keys) 5) To exit programming switch off the ignition key (unit will automatically exit programming after four keys) NOTE :- 1) Programing procedure can only entered with the system disarmed. 2) If all keys have been lost the system will need to be replaced
May 24, 2008 | 1994 Land Rover Discovery
GPS Logo
454 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
