My P50 vizio hdtv has horizontal and vertical lines running thru the screen....I was wondering if this is an expensive repair.thanks...Kahuna
    Habit-Forming:
  • 39 Answers
Lines through a flat panel (especially moving or flashing lines) are indicative of a faulty power supply. Take it to an electronics repair shop. Should cost about $130.
If the lines are static (not moving), then you've got a problem with an image processor or the column drivers- the cost can vary wildly for the image processor. If the column drivers are messed up; you need a new tv.
Posted on Sep 05, 2010
Testimonial: "thanks for the advice checking it out after the holiday.Thanks for being so quick also..........Kahuna"
  • Razosarah84 Dec 16, 2011
    We kind of have the same problem. There is a solid black skinny line running horizontally across our vizio. Not flashing or static like, it's just traveling across the screen slowly. Can that be repaired?
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
VIZIO E550VL
Replace the main board the eprom has an issue. You can get the replacement main board from www.tvcircuitboards.com
Dec 14, 2012 | Vizio E550VL 55 in. LCD HDTV
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
Vizio p50 screen flickering
You are on the right track. The power cord is not the problem, and I think that you may be better off just getting your money back. You could check into a warranty repair since you got a good deal.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 03, 2009 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio, color lines thru plasa screen
it sounds like you possibly have loss of vertical deflection it could be a ic or bad solder connections from your description and you may want to enlist your local servicer to help with this
hope this helps
Jan 17, 2009 | Vizio L32 32 in. LCD HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Hi, I am thinking of buying a used Visio L32 at a really great price.
I have never heard of pressure point lines. This particular model of Visio has a lot of problems wih the lcd panel and the lcd control module. Major problems and major expense. In my opinion a very low quality product and I will never purchase a Visio.
Feb 26, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
312 people viewed this question
Top Televison & Video Experts
Electro Med Services...
