Question about Frigidaire GLER341A Electric Dryer
My heating element keeps coming on even when the door is open and the dryer is top
  • Frigidaire Master
  • 8,220 Answers
Your heating element is broken and welded to the frame unplug the dryer'my heating element keeps coming - be2f251.jpgebaf8b7.jpgMore here
Posted on Sep 05, 2010
  • 262 Answers
You have a short in your dryer !!!!! unplug your dryer and call for service !!
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
How to check and replace dryer's heating element for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity electric Dryer -...
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Oct 01, 2011 | Dryers
How do I replace the heating element on a ge
First unplug your dryer. Open the door and you will see a couple of screws holding the front to the top of the machine. remove these screws and the top will come off. there are 2 more screws at the top and on the inside of the front panel. remove one on each side and the front will come off. you must then remove the belt from the motor and pully. this will allow you to pull the tub out and you will see the elements at the rear of the machine.
Jul 19, 2010 | GE DWSR463EGWW Electric Dryer
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
Apr 21, 2010 | GE DVLR223 Dryers
Heating element turns on when you turn on timer door open
Sounds like the door switch is broken.Fairly easy to replace.
Feb 16, 2009 | Frigidaire GLER642A Electric Dryer
Changing heating element on a frigidaire dyer
If you dryer lint screen is located at the top of your dryer your heating element is going to located at the rear of your dryer. You will need to remove the back of the dryer to get to it. You will see a housing and the element is located in there. If you lint screen is located in the door when you open the door then your heating element is located in the front. This one is easier to get to. Simply remove the bottom panel under the door and you will see the heating element right at the front on the right hand side. Make sure you unplug the dryer before working on it. If you have any other questions feel free to ask and also please let me know if this was helpful for you. Good luck and glad to help.
Jan 22, 2009 | Kenmore 63942 Dryer
Where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
Whirlpool dryer won't run
This sounds like something may be mis-wired...or there may be a defective switch contact in the timer or one of the other controls. If the heater element comes on with the blower motor not running, it should quickly overheat and trip one of the thermal shutoff switches.
Feb 01, 2008 | Whirlpool LER5636P Electric Dryer
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
