Question about Hitachi VMD865LA Digital-8 Digital Camcorder
I have a hitachi Hi8 VM-D865 camcorder and wish to transfer the tapes to my computer to produce DVD's. Can I purchace the i-link (DV) cable through Hitachi? Is this cable all that is required to produce DVD's Thankyou very much Gerry Davis
  • 76 Answers
That is a standard IEEE cable that available anywhere. As far as you being able to produce the videos it depends on your computer and its capabilities. You have to have a firewire input on your pc and also the software that makes the dvd's. I hope this helps.
Posted on Sep 06, 2010
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My sony camcorder DCR TRV19cannot be detected on my vista computer
The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System.
The Camcorder uses the USB Streaming function to transfer the videos to the Computer.
You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
The i.LINK cable is a D shaped port labeled as i, DV, IEEE1394. Please refer to your Computer manual to check whether there is an i.LINK port on the Computer.
Sony Camcorders contains 4-pin i.LINK port on it.
If your Computer has a 4-pin i.LINK port, then you can use a 4-pin to 4-pin i.LINK cable to connect the Camcorder to the Vista Computer.
If you're Computer has a 6-pin i.LINK port on it, then you can connect the Camcorder to the Computer using a 4-pin to 6-pin i.LINK cable.
You may wish to click the link below to get more details about the 4-pin to 4-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11039459&tab=Features
You may wish to click the link below to get more details about the 4-pin to 6-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040679&tab=Features
Jul 10, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
May 16, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Video transfer
You need a download hardware from Pinnacle. www.pinacclesys.com You may use a simple one PC/TV card with software. If you are from India, you may get several options like www.monarch.com etc.
Oct 01, 2008 | Hitachi DZ-GX20A DVD Camcorder
How do I transfer hi 8 tapes to DVD without the working camcorder
Greetings jamhere,
I have the same issue myself with my gillion of family tapes and my Hi8 unit broken! The only remedy I have found is to either invest in a new lower price HI8 unit, rent a unit and get my transfers done, or pay to have the old tapes put on dvd professionally. None of these options are too appealing to me, but really seem to be the only options available. If only HI8 had an adapter like VHS-C! I personally would look on some of the online resellers to see if you can obtain a unit that is lower priced to meet your needs. Investing overall in a Hi8 as your only camcorder is not advised, due to it being almost obsolete technology.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
May 05, 2008 | Video Cameras
How do I transfer my camcorders recordings from HI8 tape to a computer or DVD?
Do you have another video camera that will hook up to your computer? In the past, I've connected my old Hi-8 to my Mini DV, recorded the footage from the Hi-8 to the Mini DV and then digitized on the computer from the Mini DV. You will however need some video software like iMovie for this solution.
You can also, hook the Hi-8 camera up to a VCR or TV using the appropriate cable and view it that way.
Feb 09, 2007 | Samsung VP-L800U Camcorder
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Hitachi VMD865LA Digital-8 Digital Camcorder Logo
328 people viewed this question
Top Hitachi Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
PNiss
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
