Question about Amana ABB1927DE Bottom Freezer Refrigerator
How do you access the control board in order to replace it?
  • 262 Answers
In the fresh food compartment where the controls are is a controlboard.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ABB1927DEW14/1268/0161000/W0804101/00002?blt=06&prst=&shdMod=ard.
Posted on Sep 05, 2010
Elite he3. What does code f01 indicate?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
Error code on dryer F01 Kenmore Elite HE3 Dryer
Nov 19, 2015 | Kenmore Dryers
Maytag model MVWC200BW0 one year and 12 days old starts to fill and then drains before finished filling.of course Maytag was not helpful since warranty expired 12 days after one year. What could be t
You will need to replace the control board. Here is that part to order. Electronic Control Board
To replace the board you will need to remove the screws on the back of the console to access the control board. It is an easy repair.
Oct 28, 2014 | Maytag Washing Machines
Ge model gsh25jftabb light comes on inside. It
You need to replace the main control board on the back of the unit. Here is the part to order.
Roll unit away from the wall, unplug it, then on the lower freezer side of the rear you will see the access door for the board. Remove the screw and cover to gain access to the board.
Aug 30, 2013 | GE Refrigerators
Replacing control board da41-00524a
Here is the board to order. To replace the board, on the back of the unit there is a small access panel. Remove the screws and the panel and you will see the board.
Jun 29, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
Cycle stops after filling and sounds an alarm
You have a control board failure. Here is the control board to order.
To replace the control board, remove the top to gain access.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F1 flashes half way through the wash
Hi...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this IMAGE...
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
Kenmore Model 110.47561602 - HE2T. The drain
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Kenmore Washing Machines
What was part number
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 12, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Amana ABB1927DE Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
