Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC6A
THE FAN IS NO LONGER RUNNING AND THE MEAT ON TOP SHELF IS STARTING TO MELT. THE MOTOR IS RUNNING BUT IS VERY HOT.
  • 382 Answers
Dear sir/madam
i think your freezer have low gas problem please contect to your service technician for refill gas.
hope answer the question
thank you please vote!
Posted on Sep 05, 2010
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Sides and top hot to the touch
dear sir/madam'
i think its low gas problem so kindly contect to your sevice technician for refill refrigerent gas and also change freezer,s door seal ,
thank you
please vote!
Jul 30, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Meat in freezer is frozen but ice cream and pop-sicles are soft and mushy
Most likely your condensing coils are dirty, or the condensing fan motor is not running. Pop the cover off the bottom of the fridge and look in there and see if coils are dirty. Clean off coils with coil brush, vac or coil cleaner. Also feel around the doors. Is it hot to the touch. If so these are the two causes. If Condensing Fan motor is not running then replace it. Some times the blade can be stuck on something. ( I have found a few with mice ) Clear problem and spin the blade. If it runs then you need not replace motor. You may need to replace blade if it is bent and not turning freely.
May 15, 2010 | Frigidaire Freezers
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Frigidaire/electrolux frostfree stand up freezer occasionally seems to completely stop working. Even semi defrosts and leaves some water on floor. after a while it starts up again.Is there a problem here?...
I've had the same problem with my Frigidaire/electrolux frostfree stand up freezer. It's a major downer to go into your freezer to find all of your frozen foods (much of it expensive meat) - defrosted, some or all of it ..ruined. I sometimes wonder how many times it may have stopped working without us knowing, (since we sometimes go days without needing to open it) and just how creepy some of the meat that I am serving my family might be.
On top of destroyed groceries, the cows and chickens lives lost in vain - (aka wasted meat - I'm sensitive to that as the vegetarian in the family), it gets extremely hot on the outside when this occurs. It gets so hot, that we're actually worrying about a fire. It's almost like it is periodically overheating and going into an auto-shut down mode.
Needless to say, we are not "digging" our Frigidaire/electrolux frostfree stand up freezer.....
We are considering ditching it and buying some other model - refurbished. This just stinks... is disappointing... we paid a ton.. and now it's headed for a landfill.... (really?) JUST LOUSY!
Would LOVE a solution.... would love to know of others with this problem...
Sep 16, 2009 | Freezers
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC6A Logo
59 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
