Question about KitchenAid KSBP25IN Side by Side Refrigerator
KitchenAid KSBP25FJSS01 side-by-side refrigerator 9 years old. Refrigerator is freezing food in 2 bottom drawers and in back of 1 shelf toward the top. Is this potentially a major or minor repair? Should we be looking for a new fridge?
  • 262 Answers
Its not a major problem... It could be any of the following. The evaperator fan is not working in witch case the temps will rise soon and quickly you can check this by opening the freezer door and push the light switch if there is one and listen for the fan.
Next look at the back wall of the freezer and look fof FROST if you have frost then you have a defrost problem in withch case it could be a heater, limiter, timer, or control board.
or your thermostat is bad and is letting the compressor run longer than normal.
This should cover the most common problems.
Posted on Sep 05, 2010
Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Refrigerator freezing food on rear of shelves, deli drawer
have your thermostat setting in the right setting otherwise it will happen again and again. have someone to check it like authorize repair shop or technician
Sep 21, 2017 | KitchenAid Refrigerators
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Food in refrigerator freezing solid toward back of compartment
Been there, done that. You need to have a new computer board installed in the fridge near the top. Ours got hit by static lightning ang blew two of them in two years. When they go out, the defrost cycle fails and Ice builds up in the freezer in the back middle. Take the back vover off in the freezer and you'll see it packed with ice since the defroster is not getting the signal to defrost. order a new computer board, install it in the top of the fridge side, in the back, above all those controls on the back right side in a white case to hold the board. defrost the ice by using a hair dryer and letting all the water drain out and get it dry. Those PC boards do not like static at all
Nov 28, 2006 | Maytag MTB2456G Top Freezer Refrigerator
KitchenAid KSBP25IN Side by Side Refrigerator Logo
174 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
