Question about Fisher and Paykel WL26CW1 Top Load Washer
Fisher and paykel washing maching top loader screen does not light up?
  • 343 Answers
If there is power to the machine and the display panel doesn't show any lights when 'power' is pressed there is a good chance that a fuse has failed in the motor controller module or that the module itself has failed.
Motor modules can fail when another component fails and overloads the module.
Modules should not be replaced without first checking the other electical components in the machine for resistance and/or continuity.
It's probably best to call an experienced tech who is familiar with F&P machines. I'm sorry not to help you fix the problem your self, but you can easily do more damage to the machine by not thoroughly checking and testing the machine. A repairer who is experienced won't replace a component without testing, and you won't have to pay for parts which might fail on installation..
Good luck....Nomess
Posted on Sep 05, 2010
Top Loader Fisher & Paykel agitator makes banging noises when washing clothes
its common on these machines especially the bigger ones,chances are the suspension rods are worn out and need replacing
Jul 03, 2014 | Fisher and Paykel Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
May 20, 2011 | Fisher and Paykel Washing Machines
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Pump blockage on fisher and paykel gw708u top loader washing mach
dont do that the pump is fitted under the sytem there should be a small plastic plate at the front of the machine to get to the pump or go under the unit and its right there un plug the motor pull back the plastic lock gard and turn .the motor should just fall of ..replace as taken off good luck
Apr 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher and Paykel WL26CW1 Top Load Washer Logo
263 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
