Question about GE Security Simon 3 Wireless Home Security System
Hi -- I have a Simon Security System (not 3, as far as I can tell). I deleted a Sensor, using the keypad behind the door, now I can't figure out how to add it back. I can't find anything about it in the manual. Thanks. -- David
  • dzigas229 Sep 05, 2010
    Aplug -- Thanks so much for taking the time to field my question. I got past my main problem, which was figuring out what to press when the system says "press button on sensor". Turns out that tickling the tamper spring (with the cap removed) and/or touching the square copper piece (presumably an antenna) with it, couples it to the system. The system thinks it is "keychain remote" sensor 7 rather than "kitchen window" 7, but I really don't care. The sensor works when the window opens, and it isn't prompting me with any messages. A moral victory. Thanks again. -- David
  • GE Master
  • 19,396 Answers
Hi.
Please, let us know if the problem has definitively been solved or if you need more help. Below some documentation.
Simon® Security System
Owners manual.
User guide.
Installation Manual
Posted on Sep 10, 2010
    President:
  • 1,961 Answers
You can still bring back or add another sensor. You simply need to use an installer code to access control panel and then add up sensor and activate it manually either by opening it or pressing its buttons. Here is the steps:
1. Open the panel
2. Key in Installer Code (installer code can be found in your manual)
3. Select ADD
4. Select Sensor/Remote
5. Activate the selected Sensor ( Activation can be done by pressing buttons that comes with it or sometimes it needs to be opened to activate)
6. Choose Sensor name and group. See the manual for group listing. (Example: If you want to arm sensor door out it in group 14.)
7. Press Done when finished and run the Test to make sure all sensors are working.
I hope that is all you need.
Please feel free to ask if you still have question. Just post back.
Please do rate this answer.
Thank you for using Fixya.
Alp
arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Posted on Sep 05, 2010
Simon 3 motion sensor
If your motion detector act like a door it is because it has been program like a door, you need to go back to the program delete your sensor, and reprogram it with a group 17 , right now it's probably program as a group 13 ( instant)
Feb 11, 2013 | GE Security Simon 3 Wireless Home Security...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Ge+simon+xt+service+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 15, 2013 | GE Simon XT Wireless Home Security System
Program simon security system chimes
To turn the chime on for your door/window sensor on a Simon 3 panel push the "chime" button on the keypad. Hope that helps!
Oct 27, 2012 | GE Security Simon 3 Wireless Home Security...
Can any wireless door or window sensor be used with the ge simon
Sad to say but other brands of wireless door and window sensors will not work with the ge simon. Other sensors has different command patterns that it will not recognize the command coming from the GE Security Simon 3.
Nov 02, 2010 | GE Security Simon 3 Wireless Home Security...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
Unresponsive door sensor--Simon 3
If it is a newer model there are several setting as to which reed switch you are using or if you are using the wired option. Contact the professor.
AlarmProfessor.net
Sep 04, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon reset
In order to do this, you must have the "installer code". This is not to be confused with your master code which you use to disarm your system. Once you have this code, enter it when prompted, press delete, press sensors, when proper sensor is announced press done to accept, system announces that sensor "x" has been deleted. There is a default "installer code" (1234 or 4321) but many suppliers such as ADT change it to prevent owner tampering.
Mar 19, 2009 | GE Security Simon 3 Wireless Home Security...
My touch pad remote is not programed
Hi, drop down panel door. enter installer code. you need to know what zone it was on before, because I recommend you try to delete it first. so next delete then sensor remote button til you get to right zone, then "done" then use add button sensor remote button then if its the small remotes 2 botton press the 2 bottons. for botton press top 2.sensor group 01
Jan 03, 2009 | GE Security Simon 3 Wireless Home Security...
REPROGRAMMING HELP
go into the simon, 64321 tech code then delete and the sensor button until it tell you which one you are on and then hit done..that deletes then to ad back depending on which sensor you are using , by hitting add then sensor and going to the room or door or what ever till you find the room and here is a list of all the setting for sensors smoke 26, d/w 13 no delay 10 delay, motion, 20 delay 17 no delay depending, shocks 13 on windows always 13, glass break 14, carbon 26, keyfob 01 there are more but these are most common
Dec 30, 2007 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
89 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
