Question about GE WBSR3140DW Top Load Washer
Washing machine vibrates on spin i put the sbalizer bars there are 4 of them one was off a little so i filed it to fit and then i put my own rubber bracess on and they broke everytime it spun so i tried it again and it broke again these are very strong i thought, well the ones i have called about for this washer are about $40.00 for 4 and they must be stronger, so do you think it is the rubber bracess that is at fault, or the stablezier bars? please help dont hae money for a repair person
  • 4 more comments
  • Kirk Augustin
    Kirk Augustin Sep 05, 2010
    I don't know exactly what the parts on your washer look like, but I have worked on ones where the basin hangs on 4 pendulums. But I can't figure out what you mean by "rubber braces"? I have never seen anything like that. There have been hard nylon balls they hang from, or rubber bungee cords to act like dampers, but you really need to take a picture and put it up. I am not going to be able to find a part diagram for this washer.
  • silvia livick Sep 05, 2010
    it would be the rubber bungee cords as u put it. cuz when it spins the ones we put on our selves break as the spin cylcle hits so they must not be strong enough and the store we called said they have them for $40.00 for 4 that isnt outragous but thought we could use our own but they keep breaking during spin, and then bang it hangs off balance again. so yes its the rubber bungee that you say. should we just get the new ones?
    also i am sorry i cant take a picture but that rubber bungee thing you are talking about is what we are talking about. i dont have that kind of camera sorry
  • silvia livick Sep 08, 2010
    we got the agitator off finally and it looks good so he put it back on (husband) anyway i am wondering if the bungee that he is using or making up himself have too much slack on them so when it spins on the spin dry cycle and one breaks loose that throws the whole tub off balance. so we shut it off, i just dont think what he is using is strong enough so we are going to shop around to see if there are any that are cheaper then $40.00 for 4 maybe you could or if you have any place's that you may know of in portland oregon that maybe inexpensive? let me know? also they are called bungee's right? that is what you call them. also the stablezier bars hang freely as they used too and the one that was a little shorter then all the rest he fixed makes me wonder if they arent even he got mad at me for saying that but even a little sliver off can make it all go array. right? so it may be that the bungee's are just to slacky that is what i think cuz why would one break and the others not? i would think they all need to be the same thickness and maybe not as long as he seems to have them, they look long to me they may need to be shortened up a bit and maybe a lot thicker. let me know what you think. its only during the spin cylcle the hard last spin, and then all heck breaks loose. and it is alway one of the bungee's . thanks for all your help silvia
  • silvia livick Sep 11, 2010
    Guru can you please read some of the comment I have written you, i am not sure your getting them, yes it hangs on 4 pendulums and not rubber brace's but rubber bungee cords to act like dampers. please read the other 4 I have written to you and tell me what you think, thank you, hope your not too busy for me, I know your busy but please help before i crack LOL. thanks again. your great.
  • silvia livick Sep 22, 2010
    that is what it is called dampers not bungee cords, they call them rubber dampers
    so he went out and bought reall bungee cords the kind with hooks on them, and then cut off the hooks and made them all four the same size, then took a wire and tightned it really tight,then put the screw back on all four of them and it seemed to be working for a little while but it still does a little vibrating, nothing wrong with the stationary of the washer it has been on the same spot for years and years, and yes they have 4 little steel bars they just hang on like you said and those are fine too, but since he has been trying the bungee stuff, and opening the machince all the time. it seems now the timer switch is off, cuz it will turn off during a spin when it shouldnt and i have to go and push the knob back in and then turn it out a tad bit, and start where it left off, it does this now about 4 times till the load is done,
  • 2,019 Answers
While $40 does not seem too bad, these days everyone needs to save money. So why not try something stronger, like a real bungee. Try to duplicate the originals in length, but since the originals broke, just make them a little stronger. Bungees essentially are lots of little rubber strands tied together, and coated to prevent friction cuts.
I would also look into if there is some other source of exceptional vibration. For example, it is essential the washer be on flat, hard, ground, with all the feet leveled. And the load should be reasonably balanced. Try rocking the center spindle and the whole outer shell when the machine is off, to see if there is some other source of movement. Maybe one of the pendulum mounts is broken or something?
If nothing else, there are solid rubber tie down straps used by truckers, that are cheap and very strong. You might be able to find a way to use them instead. I find them on the side of the road so often, that experimenting with them would not have to cost anything at all.
Posted on Sep 05, 2010
Testimonial: "it has been left i just wanted to rate what he has written so far thanks for keepin on helpin "
  • 6 more comments
  • silvia livick Sep 07, 2010
    kirkx thank you so much for your help, we tried some more bungee, and still broke, so we think it is what you think the spindle so he will ck that, it is usually during the spin cylcle when it really goes to town, it sounds like the whole thing is falling apart so we run and shut it off, by then the bungees have broken again. it is on a flat hard ground it always has, so that isnt a problem there. when you say pendulum mounts do you mean the 4 steel brackets that hold the tub? cuz that is one thing he did fix, but then we thought it was the bungee as you thought too. maybe they arent tight enough? do they have to be super tight??? i always tell my husband that maybe there just not as tight as the originals. but he is going to ck the spindal as you say and we will get back to ya. 4 yrs ago i bought a dryer i had the cash then to buy the washer that went with that dryer yet i thought that this washer was so good still why bother. well now we are laid off and broke, makes me think in hinesight how stupid i was. oh well cant dwell on the past, if worst comes to worst i could maybe get lucky and find one in the nickle adds for $50.00 that someone needs to get rid of because they are moving to an aprtment. but we are still working on this i will let ya know, and i want to thank you for your help because your great!!!!!!!!!
    hi it silvia agian you said to take off the spindal? so we thought we would try that it seems kinda loose, so we took of the fabric softner thing, and how do you get the spindal off? there is no nails no screws so how do we get it off without taking out the whole tub,??? thanks be waiting for answer
    hi kirkx i know your probably at work or busy but i am waiting still for how to remove that agitator? there is no way it seems. we pry and move it up and down, ect... but no deal, is there a bolt holding it? it shows on the paper that came with the washer that it is to just be lifted off but we cant lift it off at all thanks i will be ckecking every hr thanks again for your help
  • Kirk Augustin
    Kirk Augustin Sep 07, 2010
    Sorry I took so long to get back to you, but I wanted to read up on some of the different types first. I am not really sure if there is a need to take the agitator off or not. I am just wondering why the original stabilizer rubber braces broke in the first place. I was suggesting there may be something else wrong that was causing excess vibration. It is hard to tell without being able to see it, but instead, here is a site that has a video on how to take a GE washer apart.
    Maybe you will see something different from yours?
    http://www.appliance-repair-it.com/GE-wa...
    i willl look at the video but he got out the spnner thing that we had trouble with and its all ok so we think that if the bungee's arent of equal size and one is bigger in the back then the front it may throw it all off right? that is what he is thinking cuz it would always break in the back one of them not all. so he threw out the old ones and said he is going to try and make them of all equal size and see what happens let ya know and i will watch the video, maybe we need to go buy there bungee's at the store cuz apparantly theres are the right size and fit
  • silvia livick Sep 10, 2010
    guru just wanted to say we got the machine to work now that he bought bungee cords and measured them exactly, the only problem i am having now is that the timer dosent seem to work it'll empty on its own and fil on it's own, and spin but it stops spinning during the full cycle and i have to push the knob in and back out untill its done, then i have to turn it just a smitchen to have it re fill to soak cuz it just stops and i dont hear a click, i am wondering since he had the top off so much if that could of done somethng to the timer? if so is it hard to fix? cuz i really dont enjoy turning the dial everytime it stops when it feels like it. but if i have to then i will cuz at least i got it to work, i am dissabled due to a botched back surgery so carrying a wet load home from the laundry mat wouldnt be easy on my back at all. thanks i will wait for your answer on that. silvia
    i have a question, i havent heard from you for sometime and my hubby as i said did get bungee's to fix the tub, now what the problem is even tho the machine is stable in all place's even the floor, it still on spin does a lot of hard spinning, so the knob that turns on and off the machine, seems to turn off on it's own when it spins, so i have to pull out knob, and it still wont finish,so i push knob in and then trun dial a dad bid, pull it out again until it starts again. it usually stops as it spins,and rinse's water at the same time, do you think by lifing the machine lid open he may have done something to the timer? or could it be that when it broke down the knob vibrated so hard it threw the whole thing off,? He looked at it and when the spinning comes on again i have to literally hold the knob out so it dosent turn off on it's own, and it does at times, any idea's please. i cant stand holding the knob all day long as it spins, I just got done with a load, and i had to do the same old same old, I think if one of the bungee's is off just a tad bit then it will rock the tub like crazy do you agree with me? or am i just a women? LOL i saw some on line and they are like tire's as thick as a tire rubber. anyway he went and bought the kind that have hooks on them, u know the kind that you can strap something on a car to hold something from one side to another, then he cut off the hooks and mesasrued each one, then tied it with very strong metal so it wouldnt come loose, the cords seem to hold, yet the tub as it was getting done spinning and i lifted the lid up, and watched it finish as it slowed down, it looked a little off balance still, the one's on line are $3.00 cant beat that but they dont seem to have our wahser Number so i am worried there. the stabelizer bars are hanging freely like they are supposed to, and nothing seems to be wrong, except i think its the dang bungee cords. any advice please you havent answered in a long time are you done with me ? hope not LOL thanks silvia
  • Kirk Augustin
    Kirk Augustin Sep 11, 2010
    Hi. Sorry to hear you are still having problems. I was not trying to ignore your last comments, but I did not notice that I had to hit the sign in order to see the additional comments. I guess I have never had this many comments before and did not realize they did not automatically show.
    As for shutting off at the wrong time, I can only guess.
    It could be the timer, but I don't think they are easy to repair, and expensive to replace.
    However, it could be something else like the lid switch malfunctioning perhaps.
    To check if it is the timer switch, try a different cycle, like short or gentle, if the machine has one. This should use different contacts that have not been used as much, and should be clean and fresh. If they work, then it probably is the timer. The contacts may be possible to clean, but I have never tried that.
Get a lot of vibration on the high spin cycle. Looks like I need to replace the bearings. Can you replace just the bearings? I saw the whole drum can be replaced.
It depends on the make and model of the machine you have. Some drums are bolted together with a front and a back half that split apart. some are heat sealed at the point of manufacture and can't be split. If you take the top off your machine, it should be pretty cleat if the 2 halves are bolted together (You will see bolts). Just be aware that for the noviice, this is a nightmare job. Not only do you have to get the drum out, you then have to knock out the old bearings with ppopriatly sized drifts, without damaging the seats they sit in. THEN you have to get the new ones in without doing any damage to the bearings ot the seats, then you have to get the seal between the 2 halves to seal without any leaks. I recondition machines for a living and I avoid bearing swaps like the plague. I would seriously consider consigning the machine to the scrapheap, rather than doing it yourself!
Sep 25, 2015 | Washing Machines
My Kenmore when in spin cycle it shakes all over the floor rattling and shaking
I can't offer a definitive answer but I have had a little experience.
It is possible it is spinning too fast. The brain of the machine needs to know how fast the motor is spinning in order to control the speed. The motor is fitted with a tachometer sender for this purpose. It is important any replacement motor is fitted with an identical tachometer to the original.
The brain is programmed to cycle the spin slowly at first at increasing speeds to allow the washload to settle and for most of the water to be removed so when full speed is reached there will be less vibration. Perhaps the cycle is incomplete or absent and it is starting on a high speed spin...
The washtub suspension can become worn and weak even though it appears intact...
It is conceivable the drum is imbalanced - a drum that is nicely balanced will not vibrate when spinning without a washload.
Dec 27, 2017 | Kenmore Washing Machines
Top loading washer vibrates quite a lot during spin cycle
If the machine is level and the feet are properly touching the pads it may be a fault in one of the suspension components or it could simply be the way the load is sitting in the machine during spin cycle. Towels get heavy when soaked and if the load is not balanced inside it will make the machine vibrate. Have you tried the machine without any clothes in it to rule that out?
Dec 27, 2012 | GE Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Washing machine won't reach full spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
TWO possibilities since it will spin:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
May 08, 2010 | Kenmore Washing Machines
I need a technical manual for a sears elite washing machine model # 11026922502. washing machine fills up, but does not agitate,spin.etc...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11026922502
Also see the Whirlpool service manual for these washers:
If it neither agitates nor spins, the first place to look is the Motor Coupler.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
Nov 02, 2009 | Kenmore Washing Machines
Vibrate when on spin
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2009 | Washing Machines
Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Mar 03, 2009 | LG WM-2032H Front Load Washer
LG WD-8074FHB frontloader washingmachine, vibration during spinning
As happened to me, it could be that one of the shock absorbers at the base of the unit has come adrift from its securing point.
Jun 23, 2008 | LG Washing Machines
My washer vibrates so much it actually moves the appliance. Yes, it is level. I also took the clothes out of the washer and tried the spin cycle with out clothes in it and it still vibrates.
If you call LG they actually have some rubber pads to go under the unit to stop it from sliding and it also helps with the vibrations. Part number is 4620ER4002B.
I know of people who have also gotten a thick rubber mat, stal mat, and put it under the unit. They claim that it works wonderfully.
Sgt 48
May 30, 2008 | Maytag Washing Machines
GE WBSR3140DW Top Load Washer Logo
285 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
