Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
Maytag ice maker flap keeps opening like it was possessed
My maytag side by side stainless steel refrigeraotrs ice maker flap keeps opening like it was possessed
  • 868 Answers
If the flap your mentioning is the one that opens and closes that is on the freezer door,than it needs to be replaced with the "Fountain Kit ".In this kit you will have the parts that control this problem.Replace ALL the parts that are in this kit with the parts off your old one.If installed correctly ,the problem is fixed.
Posted on May 12, 2008
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
Ice maker does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 25, 2010 | Maytag 26 cu. ft. Wide-By-Side...
ICE MACHINE DOESN'T WORK I haven't tried to fix
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Maytag MSD2352KES Stainless Steel Side by...
My GE profile refrigerator's ice maker is frosting over at the exit point for the ice leaving the ice bin. I have cleaned it repeatedly and have no clue as to the cause.
The flap door that opens to let ice drop out of the door has a bad seal or the plastic mounting arm is cracked or broken,this is allowing moisture to enter and turn to frost.This will continue to happen until the flap door is repaired,and sealing correctly.
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Malfunctioning Maytag and memory board flashing
You need a main control board and it will have to be programed but the new board comes with instructions
Mar 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
THE ICE DOOR PROBLEM
Budd, if you want to stop the flapping until service shows up to replace the high voltage board do the following: remove the drip tray, remove the 2 screws under the drip tray. From the bottom, where you removed the screws, pull out and up. The whole disp cover lifts off. Unplug the 2 harness going to the board on the dispenser. The refrigerator will still operate normally minus the dispenser. Catriver.
Dec 25, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
279 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
