Question about Creek Company 816 Outdoor Discovery Craft - Pontoon Boat - Blue
Where is my fusebox on my 1997 rinker fiest vee 266 boat
Im going to store my boat on a trailer for 5 months. Will i have flat tires when i come back? Its a dual axel trailer that is holding a 25 ft Rinker cabin cruiser that weighs 6000lb.
No you won't as long as the pressures are correct. They are pretty high around 70 psi. I store my 15 foot Boston Whaler from October to May on a trailer and have done for 10 years. With three Boston Whalers, I have only checked the tyre pressures and needed to add air once!
If you think you may lose air you cold jack the trailer up and drop it onto axle stands standing on a pad of plywood.
Apr 26, 2018 | Boating
Ford fiest cuts out
sadly only a dealer or a good local mechanic can HELp you.
Apr 02, 2018 | Ford Cars & Trucks
What is the weight of a 1996 Rinker Flotilla deck boat
depending on the size.. length and such.. there should be a weight tag somewhere near the drivers seat..usually mounted in sight of the operators' seat..
Oct 16, 2014 | Boating
Why dont my navigation lights work?
there has to be a running light switch ,or circuit breaker. look deeper into your wiring.
Aug 03, 2014 | Boating
I'm installing the Pyle plcd33mr in my 1996 rinker 180 boat and the wireing harness on the stereo does not match up with the boats. How should I go about fixing this
The trick is find the adapter which plugs into the original radio's harness. In the automotive world, these adapters are vehicle specific and readily available. The adapter plugs into the original radio's harness and the wires on the adapter are the same colors as the wire colors on the new after market radio's plug. So it's a matter of connecting yellow to yellow ,etc.
I was unable to locate adapters for boat radios, or radio pin outs . I would think they are available as the automotive adapters are.
I suggest you go to a local marine supply store and ask if they carry radio adapters for after market radios. You can also try doing a web search. It may work if you can come up with the name and model number of the original radio in the boat, and try a search using that info....
Jun 01, 2014 | Car Audio & Video
I have a 1997 Rinker fiesta vee 330 with a quicksilver duel control with trim control shifter the right side plastic handle (the one without the trim control) is broken. Also the left side outer rubber...
Hello and good morning;
I read your problem and i think i might be able to help. I believe I know what you are looking for. There is this web site and I am pretty sure you can get this part. However, depending on your condition of control shifter and problem you have to justify yourself if better to buy the whole shifter, but i feel based on your description and your mechanical abilities you most likely can replace the broken or missing parts. Here is the web site, it shows having your part and other associated parts to your shifter.
Please copy and paste this link in your browser.
http://www.partspak.com/ProductCart/pc/viewPrd.asp?idproduct=12429
mr1bill.jpeg I hope the helps you, if you have any more questions , feel free to contact me. Thank You So Much, Mr Bill from Fixya.com
Aug 04, 2011 | Quicksilver Mercury/Quicksilver Parts...
Omc specs
You will need to repost this in the correct section, this one is for vacuum cleaner repairs.
Jul 13, 2008 | Vacuums
Creek Company 816 Outdoor Discovery Craft - Pontoon Boat - Blue Logo
75 people viewed this question
Top Creek Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Creek Boating Expert? Answer questions, earn points and help others
