Question about Frigidaire GLER341A Electric Dryer
My dryer is squealing as it rotates. - Frigidaire GLER341A Electric Dryer
  • 262 Answers
Most common problem with your dryer and squeeking is the rear drum bearing. There is a kit. 5303281153
Posted on Sep 05, 2010
F*P de27cw1 top load dryer.....is squealing....as it rotates. When off, and I turn the drum it makes the squeal......I am thinking its the bearings or a pulley but I do not have a service book......and...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 18, 2011 | Fisher and Paykel DE27CW1 Electric Dryer
When dryer rotates, i hear a squeal or screech. what is wrong? Also, how old is this dryer, as I am not original ower?
drum rollers/glides, and check the idler pulley:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+inspect-pulley+repair.htm
Don't know how old the dryer is, but cost versus price so buying a part is usually cheaper then replacing a machine..Tim
Feb 26, 2011 | Dryers
Dryer is a gas dryer, when rotating it squeals as if it needs oiling.
There are several parts involved with the drums rotation and some are customer servicable, if you are handy give it a try, if you are bothered by working around gas then give the job to an appliance repair person.
Jan 22, 2011 | Dryers
My maytag dryer has a loud squeal. I replaced the belt, but the squeal persists
Check to see if the belt has landed in the groove instead of on the outside of the drum. One might assume that the groove is there for the belt, but inspection of the drum will show previous belt location about an inch beside it. To fix, rotate the drum counter clockwise while pulling the belt away from the groove on the bottom of the drum. Once it has rotated a complete revolution, it should be in alignment and the noise should disappear.
Jan 14, 2011 | Maytag MDE8000 Dryer
Dryer screeches when drum rotates. High pitched squeal.
glides/rollers:
Nov 25, 2010 | Dryers
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My dryer is squealing like crazy when rotating.. It's level and belts attached correctly. Everything seems to be rotating fine.
Sounds like the drum support rollers. They wear out after several years of operation.
See this link, and look at the parts under the schematic area labeled "Tumbler" , part description #24. Also check out the Motor Drive section.
http://www.apwagner.com/index.php?main_page=model_lookup&zenid=138m4abqv4drmfut2l5rq75864&model_num=MDE5500AYW&model_id=49651&manufacturer=Maytag
Feb 14, 2010 | Maytag Neptune MDE5500AY Electric Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Squeal noise from the dryer
check the belt tention. or you may need to lubricate the wheels the drum sits on.
Jul 16, 2009 | Dryers
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
