Question about Naxa Electronics NX-820 DVD Player
I have a NAXA NX-820. How do I set the video out back from component to S-Video? The set-up doesn't show up on tv screen anymore.
  • Andy Little
    Andy Little Sep 05, 2010
    Tried unplugging for 10 minutes, but still no video. Tried attaching video out( yellow) and audio (red and white) to video 2 on the TV. Got sound but no video. TV work on cable TV shows. Not sure what to do next.
  • 666 Answers
There should be either separate inputs setup for either your component or input 1 and s-video as the s-video wire will not carry any sound so it should be as easy as disconnecting the yellow component to the s-video however any setting that may need to be changed on the dvd player need to be made before this is done otherwise you will not be able to see the options menu
hope this helps
Robb
Posted on Sep 08, 2010
  • 2,335 Answers
I can help you with your NAXA NX-820 DVD player problem.
It sounds like your need to reset your dvd player. You are asking about component to S-Video, but I would want to be sure than the 'progressive scan' feature is also turned off on your DVD player - if the TV is not set up to receive Prog Scan then you will only see a blank screen too.
One way to reset most consumer electronic devices is to unplug them for 10 minutes or so.
I am posting your manual to the Fixya site now, and will comment back asap regarding model-specific factory reset procedures.
I hope that helps.
Posted on Sep 05, 2010
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
Dec 12, 2015 | Car Audio & Video
How do I format my naxa nx-134
If you have nothing on it, and it is reading 98% full, it may be that updates of operating software has been installed on top of previous ones, instead of overwriting. iPhones are bad for this, but the solution may be to format the unit and start adding music to your hearts content.
Jan 24, 2018 | Naxa Electronics Naxa Detachable PLL...
My Naxa NX-546 LCD TV/DVD combo no longer has sound. I've tried every menu option I can think of. Any idea what could be causing this?
Tries unplug,replug tv back about an hour later.The tv should be resetting itself back to factory setting,sound should work now.Still have the same problems.The tv Tuner signal board is shorted and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 28, 2010 | Naxa Electronics NX-546 20 in. LCD TV
How to change the volume on my naxa nx 144 mp3 player
You can change the volume of your naxa nx 144 video player by;
1.Pressing and then holding down the VOL Button for about four to five seconds
2.After you do that you will see the number near the center of the bottom of the screen on the player's screen start to blink or flash.
3.When it is still flashing press the |<< O >>| or what some people including myself call the Rewind or Fast Forward buttons until the number that is still flashing on the bottom of the screen is a diffirent number then when it was when it started flashing earlier.
4. After you change the still flashing number for the player's volume until you get it as loud or as quiet as you desire repeat the first step by holding down the VOL Button once again for about four or five seconds and....v`iola it should be adjusted to your liking now.
Oh yeah before I forget here is a friendly word of advice for you. DO NOT FORGET and leave the volume on real loud and then play your song,video or,ect. before turning you volume back down because it will be REALLY LOUD and REALLY PAINFUL ON YOU EARS.
Thank You and I hope this helps for you.
May 14, 2010 | Audio Players & Recorders
Can't program direct tv remote no code available
The codes for the Direct TV remote are in the system and show on the TV screen when you set-up the system. If not, it will find them for you by searching for the codes.
Aug 28, 2009 | Naxa Electronics NX-558 19 in. LCD TV
How do i put movies on the NAXA NX-142?
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses.
Good Luck
Apr 29, 2009 | Naxa Electronics Naxa Detachable PLL...
Remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Mar 05, 2008 | Televison & Video
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
Universal remote code
need coads for naxa tv dvd combo for an rca remote
Jun 26, 2006 | Naxa Electronics NX-517 Television
Naxa Electronics NX-820 DVD Player Logo
97 people viewed this question
Top Naxa Electronics Televison & Video Experts
Paul Gustar
Chris
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
