Require manual or instructions for GE In Wall Digital 7 Day Timer With Wall Plate #15265
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
SOURCE: I HAVE UTILITECH 7-DAY DIGITAL IN WALL TIMER.
Great! I just bought one and am typing the directions from a blown-up scan so I can read them. This us the 3rd timer that doean't seem to want to be programmed and I am forced to operate manually!
Posted on Mar 14, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
SOURCE: Hi! Do you have by
https://www.jascoproducts.com/support/manual-downloads/index.asp
Posted on Aug 23, 2010
Need instruction manual for GE digital heavy duty timer with astro
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html
2) Add comment and describe timer in detail for further assistance
Jan 18, 2013 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Have a similar question to the others asked about the GE Smart Digital Timer 7 day timer model 15086. I originally got the wires connected but the exterior lights remained in on position. The manual...
Wiring instructions and on-line manual appear on following link.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
I have tested this timer, but I'm not there to test it out for you.
Let me offer a troubleshoot list how I would start.
1) Switch located behind timer door that says OFF-TIMER. Make sure it is set to Timer.
2) 4 square buttons located behind timer door that sit in each corner. These are override buttons, and should turn lights on-off. Push each one separately.
3) Check wiring against instructions shown on link above. This timer will not operate unless wired correctly.
4) Ground wire broken off? Each cable that enters a box can be pulled a bit further so maybe you can grab some of the ground.
The ground is not critical for timer operation -UNLESS- you are using it to power electronic clock inside timer.
Normally white neutral wire is used for clock electronics, as described in wiring instructions.
5) Conflicts in programming. If 7-day programming has conflicting days or hours, timer will not operate as expected.
Check programming.
6) Reset timer and start over.
7) I test timers, and some arrive defective. GE makes a good timer, manufacturing timers for many decades: 15086 is sold at Home Depot. Buy another one and take back defective one.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 10, 2011 | GE Electrical Supplies
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
http://waterheatertimer.org/ST01C-program.html
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I need the instructions for GE 15150 digital timer
The GE 15154 and GE 15150 have same manuals.
Difference between both timer is one has 2-prong outlet and other has 3-prong outlet.
See products at Amazon.
http://www.amazon.com/dp/B0035GAXA8/?tag=picc-20
http://www.amazon.com/15150-7-Day-Plug-Digital-Timer/dp/B0033ZV634/ref=pd_cp_hi_0
Manual for 15154 timer
http://waterheatertimer.org/pdf/GE-15091-Manual-eng.pdf
If this manual does not match your product, add a comment.
Your feedback helps fixya provide accurate and free answers for folks like you.
Dec 15, 2010 | Jasco 15150 7 Day Digital Timer 1 Outlet
GE 15 amp 7-Day In-Wall Programmable Digital Timer Model # 15086 Internet # 100685863 Store SKU # 543414 ------------------------------------------------------------------------------- I...
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Dec 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Can I download an instruction manual?
You posted under GE 14079 and 15089 timer
Manual:
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
Add a comment if this is not your timer.
Nov 29, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
