One of our EuroCave wine cabnets keeps shutting off, then turns on randomly the next day. It has been going on for about a year.
    Problem Solver:
  • 5 Answers
Probably over heating but you have not given enough information. Is everything turning off or ..........
Posted on Sep 05, 2010
Excess condensation in my eurocave 266
Check the door seal gasket is sealing without any gaps. Check the ambient temperature isn't too high, and check the condenser is clear and aired.
Apr 20, 2014 | EuroCave Comfort 266 Connoisseurs Package...
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
When plugged in, the compressor doesn't activate. When you press the test button, the compressor turns on. After doing that about fivetimes, the compressor won't even flip on? This is a Eurocave Model...
if you keep starting it it will quit any way . but this sounds like a start relay or a bad or run cap / but you could have a bad compressor also . and if running on a long ext cord it cause this problem so ck these / hope this has helped mm feed back pls ..
Nov 25, 2010 | EuroCave S256T Wine Cooler
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
No light, no fans running, nothing. temp gauge still working
It is possible that the unit has a switch somewhere which may have been accidentally switched off? On some units you can switch the complete unit off by turning the thermostat counterclockwise.
Mar 09, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
