Question about Roper REX5635E Dryer
My dryer is a roper model rex5634pq0 and it will not start now.I did two loads and when i put the third load in and hit the button to start it start for a second the stop and now nothing.
  • Roper Master
  • 8,220 Answers
Look for air blockage that would cause rapid overheatingmy dryer is a roper - a7bf2e2.jpg93a3c41.jpgJunk cause the fuse to blow. And continue to blow.
Service Manual and more here
Posted on Sep 05, 2010
Roper dryer RAS7133RQ1 won't start
For starters, a user manual for your dryer can be found here.
Jun 02, 2008 | Dryers
Roper dryer will not start. Had just finished drying a load of clothes, put in the next load and it wouldn't start. The timer still ticks.
Maybe you door switch has broken?
The little tab should click.
Another possibility is dryer overheat due to lint buildup
8_17_2011_3_52_38_pm.jpgSee that white skinny thing mounted next to the air temp control thermostat? That thing will melt if too much junk gets into the lint filter or vent pipe. If it does it kills the door circuit and the dryer is dead in the water. More here
Aug 17, 2011 | Roper RES7646KQ Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
I have a 3406075 roper dryer. it was working just
roper are the same as kenmore, in the back of your dryer there is a white fuse about 2 inches in length, due to bad ventillations, overheating these will go bad, causing dryer not to run at all..
Aug 20, 2009 | Dryers
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Will not start
Try a different spot on the timer and see if it still does it.
Mar 09, 2009 | Roper RES7646KQ Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
119 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
