Question about Toshiba Satellite A10-S100 Notebook
Hard disk thanks for the previous solution dude i just want to ask an other ? i have a 30 gb hard disk in my satellite A10 laptop i just wanna up grade it how can i change my hard disk
    Master:
  • 538 Answers
Not too hard..should be a couple of small cross screws under the bottom, just remove them, and slide out the old drive..
Posted on Oct 19, 2008
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Hard disk capacity increase
          yeah you need to replace the old hard disk to new IDE 120GB hard disk.
          Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
          Hard Disc
          hi,most laptop hardrives are the same type  (IDE,SATA are your two main type)
          yours is a IDE HDD just have a look online for one or go into a computer shop
          (P.S if you upgrade you will have to coppy all your files from your old HDD to the new one)
          hope this helps
          Sep 04, 2008 | Toshiba Satellite A10 Notebook
          Hard disk removal and replacement
          You can download the service manual at the link below
          http://www.eserviceinfo.com/downloadsm/26986/Toshiba_2400.html
          This is not going to be exact because its just the series manual but good enough to be able to do it.
          Sep 01, 2008 | Toshiba Satellite A10 Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          Drivers
          The drivers come on a DVD with the computer. Otherwise they can be downloaded from Toshiba. Is there a particular driver that you need?
          Drivers.com is also a source.
          Windows XP from Microsoft
          May 09, 2008 | Toshiba Satellite A10 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Want To Replacing My Toshiba A10-S330 Hard Disk
          Normally you can upgrade to a new hard disk to the next bigger size, so from 40 Gb, then perhaps a 60 or even an 80 would work. Even if the BIOS/motherboard would not recognized the new size, Windows XP would and be able to access it.
          However, I don't think that the size should really be the main concern. I think that your selection should be based primarily on the power consumption. Most laptops have a preset power distributed to its devices. If you are going to use a bigger size HD with a bigger power consumption, Windows (or even your BIOS) might recognize it but the power distribution might be over worked.
          My suggestion would then be go to the next size but keep in mind the power rating/consumption of the old when selecting.
          I am enclosing an image of my laptop's HD. Pls note the rating DC+5V 0.7A for this 60Gb HD. The 0.7A is its current consumption/rating.
          Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
          Good luck and kind regards.
          Dec 12, 2007 | Toshiba Satellite A10 Notebook
          Open Questions:
          Toshiba Satellite A10-S100 Notebook Logo
          96 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
