Question about Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS)
Configuring the usb
Just installed the driver and i cant use wifi as stated in the product manual.
im using the ff
connection on first pc asdl line
i also have a asdl modem
connected to a dlink ethernetbroadband router
all my tcp/ip configurations are on automatic/auto retrieve ips
i have dynamic isp
tray says limited or no connectivity
  • 70 Answers
First, make sure that the device is working properly on the device manager of your computer. Then, set the wireless settings of the router to the wireless adapter. You can use the wireless utility built in to windows (XP and Vista) or the utility that came with your adapter to fix that.
Normally, the limited or no connectivity may mean that there is a wireless security set on your network and that the network key is set incorrectly. If you are using Vista or XP, try to remove the preferred networks and reconnect once again with the correct key.
Hope this helps
Posted on May 12, 2008
Printer canon pixma mp495 multifunctional
Since you've already performed a Factory Reset, which ought to take care of anything along the lines of corrupted system files, you might want to double-check that you have the correct drivers. Canon Support Drivers PIXMA MP495
Once you have the correct drivers, try doing a factory reset on your printer while it is not connected to your computer. Once complete, try using the USB cable that came with your printer to connect it to your laptop and install the drivers.
There is the possibility that your printer, even after a factory reset, is trying to automatically use WiFi for its connection to your laptop. Assuming you're using DHCP and not static IP addresses, try giving your printer a static IP address, as it may be fighting with some other LAN device for a particular IP address.
If it turns out you do have the correct drivers and you are using WiFi for the laptop to printer connection, I would suspect something is wrong with the WiFi connection on your printer's side or in your router's configuration. Make sure you have the printer's MAC address in the appropriate table in your router's filtering configuration, if you're running MAC address filtering.
Apr 06, 2014 | Computers & Internet
I have a compaq presario sr1850nx hooked uo to Comcast broadband modem Motorola SB5100. Everytime I start or reboot my computer my connection dies. I use the comcast tool to diagnose my connection and it...
no operating system stated, wow, 14 windows and zillion linux. and PS2 OS. even freedos.
I have no idea at all what you have there;.
is this wifi or
Ethernet cable lan connected. tell helper wired or wireless.
then be more accurate as to what is there.
card, what network card, name it, model, and number.
its a desktop and as all desktops vast things can be fitted here.
Wifi card PCI, WLAN
Nic USB dongle
Wifi USB dongle.
we cant see what you have there, a photo works or words.
my guess is wifi dead, as most post here, due to complexity of wifi.
if not say so please.
Sep 09, 2017 | HP Compaq Presario SR1850NX (ER925AA) PC...
Wireless will not work light stays amber color Using cabledsl now. Wireless came on once when using cable dsl . So I removed cable and was able to surf. I shut down for night and put on next day -just...
Presario V6210US Notebook
wifi is complex. unlike simple wired Ethernet.
why not use wired first.
why jump the gun and guess, and pick the most hard and expensive fix first. when you car misfires do you replace the engine,first?
what wireless card..? on modern PC its hidden inside.
on super old PC LT its a PCMCIA card plug in
on others its a USB dongle. (there did all 3 for you)
what OS.???????????is this XP?
what router (wifi do you have?) (the box with antennas")
The router makes the DLS connection with a pass word
do all other wireless device
is Verizon your DSL service provider, really? mines ATT. land line + DSL, my line is cut in half now, for ever. (never again ATT me)
but we do not know what you have there.
nor how far the notebook is from said (unsaid) router.
the real problem here is the now RETIRED PC notebook
HP does not support it now, so getting drivers is hard.
proof of that.
here is a short check list and HPs
1: can others PC connect in your home to wifi. or from CELL?
that must be done first, to see if A: its router issues. or B: your PC.
using your wifi login credentials.
2: we make it to B its your PC for sure.
then read your manual called trouble shooting
id go to device manager first see if the wife card is there , and ok.
your wifi card is mini-pci card inside mounted to the MOBO.
first connect a CAT 5/6 cable from the ethernet port of your PC
to the router,
do you now get , internet connected, if yes good, if not the router may be configured wrong.
if yes, good
we now go to device manager, and look for the wifi module
if the module is there in DM. right click and and lit windows
plug and play find your driver. this way, using the ethernet cable.
see? (to get drivers takes a connection and ethernet is the joy of life here)
ethernet is wired connected.
if ethernet fails we work far more hard, lacking any connections
or a working PC .
again, no OS stated, is this the stinky XP? the viruse magnet.
your CARD. I bet its not bad !
v6000 mobo red arrow is ethernet. jack
v6000-ooptjg14f2uaokq3pusqdg3g-1-1.jpg if your OS is not dead, and has all the origional HP drivers
all loaded an not lost. then this magical port just works
you plug in the CAT5 cable and bam, connected. in seconds.
this is always the best way to fix computers at home.
get this wire working first, and now that you have internet working
you can do vastly more things even fix WIFI.
Aug 03, 2017 | HP Compaq Presario V6210US Notebook
I cant connect on wifi..since this bldg is a wifi zone but still can't access..i need to see the manual to know how to operate this netbook since im new on this gadget..thanks
every unit if the configuration is right not possible to connect on wifi around you..check the configuration/access control...( username/password/ of setting of you pc.. you need to check it all
Jun 25, 2010 | Everex CloudBook CE1201V Netbook
Driver for windows 7
According to the Hewlett-Packard support website, DOWNLOAD the DeskJet 3600 Series driver for Windows 7. It is equal to the USB driver for the DeskJet 3325. At the present time, the Deskjet 3600 Driver is available thru WINDOWS UPDATE ONLY. Enable WINDOWS UPDATE on your Windows 7 PC and manually download this driver.
At this time, a full feature Windows 7 driver solution is not available for your product.However, a compatible print driver solution for your product is included with the Windows 7 operating system. There is no need to download any additional software. Follow the steps in this document to identify the print driver that is compatible with the product, install the driver, and then configure it in Windows 7. When this driver is installed, you can use the basic functions of the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif), and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next.
  9. NOTE: If your HP product is available through Windows Update, click the Windows Update button to select additional print drivers. You must connect to the Internet before using Windows Update.
  10. In the Printer name text box, type the product name and then click Next. The print driver starts the installation process.
  11. NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.When the installation is complete, a message displays on the computer stating that the product was added successfully.
  12. In the message window, click Finished.
  13. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  14. Click Close (c01900743.gif) to close the window.
Follow these steps to configure the installed driver.
  1. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  2. Click the Ports tab.
  3. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  4. NOTE: If there is more than one USB/DOT4 port available, select the USB/DOT4 port with the highest port number. To see the full port name, widen the ports row in the Properties dialog box by placing the cursor over the vertical line between Port and Description, and then click and hold the mouse button. Move the mouse to the right until the port name is visible.
  5. Click OK.
Jun 07, 2010 | HP DeskJet 3325 InkJet Printer
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Problem with internet connection
Try to uninstall the wifi drivers , and to re-install them
Nov 18, 2009 | ASUS Eee PC 900 Notebook
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Asdl modem
? You don't need a driver for the modem unless you have it hooked up via usb. If you are using USB go get a PCI nic card and install it. That's an easy way around needing a driver
Jul 31, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS) Logo
151 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
