Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all grass and debrie. Starts and runs great other than that.
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 86 Answers
SOURCE: gth2548 belt diagram and steering trouble
Go to searsparts.com type in your model number it should show your diagrams and parts for your mower
Posted on May 12, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Posted on Jun 10, 2009
  • 21 Answers
SOURCE: blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Posted on Jul 27, 2009
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a husqvarna riding mower that when i engage the blades the engine stops running
Could be something jamming a blade or belt. With the engine OFF and the key OUT make sure the blades and belts all move freely by hand. Clear out all grass and c**p from the blade and belt areas. You may have to remove the blade deck to do this - instructions are in your manual or download a manual from the Husqvarna website. Good Luck!
Sep 07, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna clogging problems
make sure your deck is scrapped out after every 8-10 mows, make sure your blades are sharp. I'm assuming you have a bagging system. Make sure you have the correct blades on your mower. Blades need to have a high wing in order to push the debris out correctly and make sure there are no other obstructions in shoot and always run engine at high rpm.
May 13, 2010 | Garden
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lots of smoke when I engaged stuck blades - now runs roughly
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
