Question about Westinghouse Dishwashers
Leaking door on westinghouse tri clean dishwasher
  • Westinghouse Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 07, 2010
Westinghouse SB921WG dishwasher leaking even when not in use.
I would start by checking the hoses to the machine as well as the fitting connections.
Aug 27, 2015 | Westinghouse Dishwashers
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Me and my partner just bought a new house and yesterday we tried the dishwasher for the first time. I'm not sure which model we have, but it is a white Westinghouse Dishwasher with 5 wash options. The...
If the dishwasher has been setting for a long time the seals in the pump could of dryed out. Go ahead and run the dishwasher again and it could seal itself back up if not..... you will need to call a repairman to replace the seals. Or buy a new dishwasher if the unit has some age on it. You will get a new warranty..... I would also tell your realitor about it and maybe she could help you. The appliance may have a 30 warranty with the purchase of the house.......Hope this helps...
Mar 17, 2011 | Westinghouse Dishwashers
Change door seal in westinghouse SB 907
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Jul 17, 2010 | Westinghouse 24 in. MDP531 RF...
There is a slow leak coming out the front right hand side of the dishwasher. How do I stop this?
Check the door gasket on the right hand side. See if it is damaged or not aligned properly. You may need to replace the gasket.
Sep 13, 2009 | Westinghouse Dishwashers
Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Leaks water
There are 4 screws holding that kick plate on. Normally, they're 1/4" drive. Lay on the floor with a flashlight and look at all 4 corners (between the kick plate and the door and near the floor).
This is how to get the panel off, but without a make and model I can't help any further. If you could provide those, we can figure out how to repair the leak. Just let me know, OK?
SG
Apr 05, 2009 | Westinghouse Dishwashers
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Westinghouse freestyle 920
was there damage to the door,when the door closes is it closing freely or is it hitting the cabinet on both sides it may need to be pulled out about 1/2 "
Dec 29, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
116 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
