Question about Ovens
Wanting to set time on black and decker microwave oven model No BMO700S thank you
For the B&D model BMO700S press the buttons in following order:
1/ Clock button
2/ Cancel button
3/ Type in the time (NOT 24 hr clock time eg 5.32pm will be typed in as 0532
4/ Clock button
Congratulations! You have completed the task!!
(Information from Vasilios of Rosanna, Melbourne 26/09/2013).
Posted on Sep 26, 2013
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Microvave control panel is locked and only shows 888. How to I unlock the control panel. I have tried plugging and unplugging it.
Hi and welcome to FixYa, I am Kelly
I really wish you had provided a make and model number but.. here goes without a model number.
888 is what happens when you lose power on many microwaves. You simply push stop / cancel then you have to set the time by pushing CLOCK enter current time and CLOCK again. You should be able to use your microwave normally after doing this.
If this does not correct your 888 problem please respond with a make and model number so I can look up your model.
Thanks for choosing FixYa and Happy New Year,
Kelly
Jan 01, 2011 | Ovens
Black n decker convection/toaster oven, no power at all. it just stopped working. I have it apart, any ideas to check
Heating element has stopped working. I suggest replacing the system, (unless you want to burn your house down.) If this is not replaced properly, you could very well do just that! :)
Nov 15, 2010 | Ovens
My microwave oven (ms143sce) is displaying this error " - S E - " . None of the buttons want to work, if pressed nothing happens ?!?
It means shorted key panel. You need to replace it. I suggest going to Repair Clinic, enter the microwave's model number. See if they have the replacement touch pad for you.
Thank you for using Fixya and you generous rating will be much appreciated.
Oct 20, 2010 | Ovens
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Whirlpool oven/combo unit
http://www.repairclinic.com/SmartSearch/smartsearch.aspx go here enter your model number then under parts select all parts not listed and its on page two
Feb 08, 2008 | Ovens
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
211 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
