Question about Navman NavPix N60i GPS Receiver
Speed I have the speed limit on my navman set at 60 kph and would like to change it. How do I do this.
Asdsad
Posted on May 12, 2008
What is the maximum speed pontiac fiero 1983
In December 1983, Car and Driver clocked a four-speed Fiero SE from 0-60 mph (0-97 kph) in an uninspiring 11.3 seconds, reaching a top speed of 105 mph (169 kph).
Pontiac Fiero The Definitive History
Below are speeds related to 1984 and above.
Fiero Top Speed once and for all
Sep 03, 2017 | Pontiac Cars & Trucks
Hyundai Avante (Elantra) green
a small rubber vacuum pipe connecting to the injector system / inlet manifold. Sometimes this pipe perishes and allows air to enter thus decreasing the vacuum. The engine then cuts out. It's simple to check and replace the tubing where necessary. You may also notice the engine cutting out when traveling at speed and one suddenly slows down.
Sep 27, 2008 | 2000 Hyundai Elantra
Can anyone please tell me what the legal speed limit at Water Street Spring Hill Queensland
suburban streets is50 kph
main arterial streets is 60 khaas boundary stret band leichardt streets are the main arterial streets , water street is 50 kph
May 22, 2017 | Miscellaneous
On my steering wheel there are 3 bottoms. Button one is a large botton with a clock wise looking option. What's this? Now there are 2 buttons on the right hand side of my steering wheel. One botton...
this is controls for your cruse control. The clock looking button turns it on. The + set is the button you press when you are at the speed you want to stay at. the same button and the - button are yo adjust the set speed +2 kph or -2 kph that goes in 2 kph increments. So for example if you press the set button and you decide you want to speed up 10 kph... press the + button 5 times... this will increase the speed by 10 kph. and of course the opposite happens when you press the - button.
Jan 06, 2015 | Ovens
HOW TO REMOVE SPEED LIMIT ERROR FROM BMW 525I 2004 MODEL
If this is not a limit you have set on your indash menu system..try removing the battery negative terminal for 20 min. ** Dont leave your keys in the car or close the boot. When refitting the battery , if possible make sure the side ligts are set to the On position. Dont mess with the battery refitting . put it straight on ..firm!
I f this does not reset the facia info it will require scanning with a quality unit to verify if the fault can be cleared from memory or is a facia unit specialist repair (these do fail .. see BBA-Reman).
Cheers
Roger
Apr 21, 2014 | 2006 BMW M5
Civic 2001 when reaches 140 kph check engine comes on and engine speed reduced to high of 60 kph. stepping on gas does not increase speed. it runs normal when engine cools off and check engine light...
Check that you have not reached the engine rpm limiter and the CPU is going into limp home mode. Run fault codes as the engine light comes on it may tell you the problem
Oct 06, 2013 | Cars & Trucks
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Feb 22, 2013 | Precor 932i Treadmill
In Germany on an American Spec 2006 Kawasaki 636, Trying to figure out if I can change stock Mph to Kph? I heard there was ways by pushing gauge buttons but only tach's shift point is changeable this way...
The only difference between the mph and kph is the speed "O" face. I buy bikes in the US and use them in Canada "metric" most Honda's you can just change out the Speedo. Kawasaki if you can take the speed "O" apart to get at the face then you should be able to just by the face and install it.
Another way and I've done this many times is to get red dot stickers and put at specific speed like 60 and 70 kph for in town 80 and 90 for secondary roads and 100 for HWY. What I'm doing right now with my Honda Magna is turning on my bike GPS which I mounted over the Speedometer that thing is dead nuts accurate. Lots of ways around it
Apr 06, 2011 | 2006 kawasaki ZX-6R
Navman NavPix  N60i GPS Receiver Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
