Question about Nuova Simonelli Program VIP Coffee Maker, Espresso Machine
How to replace gaskets on nuova simonelli - Nuova Simonelli Program VIP Coffee Maker, Espresso Machine
SOURCE: Nuova Simonelli Premier
Could be a couple of things. You will know if the pressure is bouncing around by watching your gauges. You want to pull between 9-10 bars when pulling a shot. The programming issue could be the fact that if it is used it could have what I like to call
a touchy brain board. Those do have to replaced every so often depending on how much use the machine gets. You can reprogram whenever shots start pulling bad until you have no choice but to replace the brain board. They are cashy. To program: push the stop and pitcher button at the same time and all lights will start flashing on that head. Have your grind set, use a lined shot glass and measuure your shots according to short or long, watching the flow, crema etc. The ultimate shots pull between 25 and 28 seconds.
Hope this helps.
Posted on Feb 12, 2009
  • 10 Answers
SOURCE: nuova simonelli appia 1 ....pump will not stop pumping so tank fu
Your level probe is on the right hand side plate of the boiler, normally with a red wire leading to it.
I would take the probe out (spanner reqd, obv. with no pressure in the boiler) and clean it with wire wool.Scale often causes the probes to malfunction.
Then make sure when you refit the probe, the part of the probe in the boiler faces down.
Posted on May 08, 2009
Fame_Guru
  • 483 Answers
SOURCE: I bought a Nuova Simonelli Expresso Machine at an
you have it :
http://www.nuovasimonelliusa.com/grinders.html
fame !
Posted on Jun 23, 2009
EsWorld
  • 1618 Answers
SOURCE: Describe your Nuova Simonelli Mac 2000 I Group
Either the brew solenoid is bad or the shower screen is blocked or the metering jet on the top of the head is clogged.
Posted on Aug 28, 2009
EsWorld
  • 1618 Answers
SOURCE: My Nuova Simonelli Mac digit pushes steam out of the group
The metering jet on the top of the boiler is blocked.
Posted on Nov 26, 2009
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Aurelia fuse replacement
go to nuova simonelli usa and download the parts manual and locate the fuse.
Apr 05, 2014 | Nuova Simonelli Coffee Makers & Espresso...
How do i change the gasket on my nuova mac 2000. Could you email me instructions?
Remove the shower screen and diffuser, this first step is a precaution, then using a scratch awl or an ice pick pry off old gasket, make sure there are no pieces left in the head and clean, then insert new gasket.
Aug 30, 2010 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Our Master coffee is broken but can not find the new one
I would google Nuova Simonelli, they have branches worldwide.
May 27, 2009 | Nuova Simonelli Master Espresso Machine
Nuova Simonelli Program VIP Coffee Maker, Espresso Machine Logo
136 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
