Question about Dometic Rooftop RV Air Conditioner
Air conditionerwon't turn on. It worked yesterday. Circuit breaker was tripped, I reset it but it still does not work
  • 674 Answers
I would remove the cover on top and check for any wires that may have came off or burnt off. Next check for a fuse on the circuit board and check the condition of the contactor. Try turning the fan motor by hand to make sure it hasn't locked up. You may also want to use an ohmmeter and check the fan and compressor windings. Also check each fan and compressor lead to ground to make sure one of the motors haven't become grounded internally.
Posted on Sep 05, 2010
I have a Proform XT 90 treadmill that was recently purchased. After I brought it home, I plugged into my power strip and everything worked fine. Yesterday I plugged it in and nothing lights up on the...
cocopoi-
A couple likely issues would be:
1. Is the starter key installed correctly?
2. Has the onboard circuit breaker tripped? The breaker reset is next to the on/off switch, which is on the lower front of the unit. Press the button once firmly. If this was the problem, the treadmill should work again immediately. If the onboard circuit breaker trips repeatedly, there may be a short circuit in the machine, in which case you may be at risk of shock if the unit is not repaired properly.
3. Has the circuit breaker or fuse for the particular outlet you are using tripped? Try plugging another electrical appliance into the outlet. Does it get power? If the circuit breaker or fuse has tripped, that particular circuit may be overloaded or faulty. Only an electrician could tell you for sure.
Please followup if you need further assistance.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
1996 harley 883 headlight flickers off real quick every minute or so with a clicking sound and my front and rear blinkers are dead. I turned it off and pulled out the key and it still made the clicking...
You have a short in your electrical system somewhere that is causing your circuit breaker to trip. Harley uses automatic reset circuit breakers rather than fuses. If you get a short in your system somewhere, the current though the circuit breaker will cause it to trip. After a minute or so, the circuit breaker's bi-metal strip inside will cool and the circuit breaker will reset. If the short circuit still exist, the breaker will again trip.
To help find the source of the problem, you must determine which circuit breaker is tripping. In this case it sounds like the "lights" circuit breaker. Since your turn signals are on that circuit and they are not working, I'd start there to look for the reason.
When you turned off the key and it made the clicking noise again, this was probably the circuit breaker resetting itself after you removed the voltage and current flow through it by turning the switch off.
Good Luck
Steve
Jan 04, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Oct 06, 2010 | Square D Trilliant 40 Amp Circuit Breaker...
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Circuit breaker on power cord does not reset
why did it trip? If you push test and it does not trip, check your circuit breaker in your panel
Jun 20, 2009 | Friedrich QuietMaster RS10J10 Air...
Is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
May 15, 2009 | Weather King 10AJA4201AH Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
271 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
