Question about Kitchen Ranges
I have an e series rainbow vacuum cleaner. The low speed is no longer working and the high speed varies a lot, thus the vacuum suction. It goes from high speed to low speed and then back again to high. I checked the bearings, they are OK and I cleaned the motor thoroughly but the problem continues. Can you help with this?
  • cjcastillo_w Sep 08, 2010
    The advice is insufficient, I already found a solution by other means. I will like a refund.
    Thanks
    Because it went by itself under that category. Thanks but I found what is the problem. I will like to get a refund.
  • 2,973 Answers
It seems that the speed regulator needs change as it is malfunctioning. Please replace it.
Posted on Sep 09, 2010
    Top Expert:
  • Kitchen Ranges Master
  • 75,197 Answers
Need the exact model number off this device, i assume it is not a Kitchen range, that is what u have it listed under as a caragory, is that what u wanted?
Posted on Sep 08, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link and go through the article regarding your query:-
http://www.howeverythingworks.org/supplements/vacuum_cleaners.pdf
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 05, 2010
The e series rainbow 2 speed works only on low speed. High speed will not run. What is srong?
It is either the switch or the controller. Call us and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
800-523-0510
Jul 23, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum works on low but not on high
If it doesn't turn on at all in the high speed mode it's most likely a faulty switch.
Jul 21, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow vacuum will not start in high speed but runs in low speed
Yes, it sounds as if your controller is bad. Give us a call and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
800-523-0510
Apr 05, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Why would the motor of a Rainbow E series vacuum cleaner be made
The bearing for the single speed eSERIES is available on our website. Click here
RainVac
www.rainvac.com
800-523-0510
Mar 18, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacum works on low but not on high??????
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other hacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jun 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Low suction
Is the suction low at the tank after you disconnect the hose? If it is strong there, then the hose may be clogged. You can unhook the hose from the wands to see if you have suction or not. If you do, then look further down all the way to the brush roll. The other possible is if no clogs, check the filters, on the E series, there is a filter on the back, there is some also had one in the top and you would have to take it apart to get to it. One other is that the motor is not running at top speed and may have to be replaced. It can sound ok, but will have reduced suction. If you suspect the motor, check your owner manual, some of these newer ones had a long warr. period on the motor.
Feb 13, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Low suction
Is the water seal in place or missing? Another cause would be a bad motor, running at a slower speed will mean low suction. If it is a motor, then you would have to replace it. Is the suction low at machine without the hose, if it is ok then may be a clog in the hose.
Feb 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
