Toshiba satellite a200 shutdown or will not start up with power adopter insert,but runs ok with battery's only.What would be the problem? Laptop is just over 2 years old.Battery life is 1 hour.This happens after i installed w7. was Vista when i got it.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
We have a toshiba a200 satellite and it has no power.Took battery out and put it back and still no power. Charger is ok have checked it.Any ideas why no power?
There maybe something wrong with Toshiba power provide module but shouldn't be matter of toshiba satellite a200 laptop battery. It is a difficult problem can't be solve by some words or sentences,you'd better go to a professional laptop repair engineer to repair it. Good luck.
Feb 17, 2011 | Toshiba Computers & Internet
No power from laptop just a flashing blue light,
THE SYSTEM SHOULD BE CONNECTED TO POWER SUPPLY AND REMOVE THE BATTERY AND TRY TO ON THE SYSTEM .IF IT BOOT THEN AFTER THAT INSERT THE BATTERY SO THAT IT CAN CHARGE VERY WELL OR CHANGE THE BATTERY....OK RATE THIS SOLUTION
Apr 30, 2010 | Toshiba Satellite A200-0ET00X Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Have a satellite a200 series laptop wont power up ,power light comes on briefly then goes out
ok unfortunatley souns like its a motherboard issue as its either power of motherboard issues that stop laptops running. i would take the case off give it clean..... if you can there should be a small battery on the main board take it off and replace it and see if starts if not the its dead. and will need motehrboard replacement
Feb 02, 2010 | Toshiba Computers & Internet
Toshiba a200-1VO
hi
please open the laptop then push the semos battery plz start the computer then shut down then enter the semos battery then start computer password is reset other plz install the bios this laptop
Jun 06, 2009 | Toshiba Satellite A60 Notebook
WILL NOT TURN ON WHILST BATTERY POWERED
please try and update your BIOS
http://nordic.computers.toshiba-europe.com/innovation/download_bios.jsp?LNG=18&service=ND
i can send you the direct link for the download if you tell me what short model number your computer has. you can read this under the computer PSAExx
May 27, 2009 | Toshiba Satellite A200-19501F Notebook
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
