Question about Canon Office Equipment & Supplies
Hello I have a canon lbp2900 which has been functioning well. When I try to print i get a message asking me to insert a toner cartridge, however there is a toner cartridge in the machine and I am sure that it has not yet emptied. I have switched off, taken the cartridge out and re-inserted but ther error warning still occurs. Do I need to replace the toner cartidge? The warning does not say that the toner is empty, it simply says insert a cartridge.
    Problem Solver:
  • 5 Answers
Just open the door and pull it out the toner cartridge, inside the printer in left hand side u will find a sensor in grey or while colour , from ur finger just check its functioning (up and down function) if it fails then open the back side cover there u will find one metal plate in silver colour open it and in right hand side there are sensors the cartridge sensor is also there only in right hand side refitted it and ur problem get resolved
bye
wasim
Posted on Jul 30, 2009
I just posted the similar problem recently. After talking to canon printer service tech, this is what solved my problem:
1. open the top cover and remove the cartridge
2. Inside the printer, these is black roller (with sponge&soft material). Press this gently couple of times
3. below this roller, there is a gray roller. press this roller upward couple to times gently
4. insert the cartridge and try to get print out
hope that helps.
Posted on Apr 01, 2009
  • chinamom2 Aug 06, 2011
    mattfixya posted this fix for the same problem on the LBP 3000. I tried it for my 2900, and it worked--though I have no idea why!
    "My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go."
    -http://www.fixya.com/support/t205557-can...
I have cannon LBP2900 printer, while print out paper comes left side with left margin pressing , but letters are all ok. only left sede paper look like compressed how can solove?
2 some times right side end margin side ink spread over so letters are vanishing left side.
above all this i ask him my re filler he is saying name of Teflon damage, Is true to change or how can ? bcas this part is cost. .
Posted on May 20, 2010
Mattfixya posted this fix for the same problem on the LBP 3000. I tried it for my 2900, and it worked--though I have no idea why!
- http://www.fixya.com/support/t205557-canon_lbp_3000_tells_me_needs_new_toner
Posted on Aug 06, 2011
Error message: Install toner cartridge
Look at where you install the toner cartridge. There should be a little tab or button or lever that the cartridge pushes once inserted. In fact, there is likely to be several, not counting the doors you opened to get where you are. Often, one of these tabs breaks, or lever bends, or button is misaligned. Just look around where you put the toner in, and ask yourself, "what is this supposed to do?" and as you go, also ask "what is expected that is not happening?"
Oct 19, 2012 | Canon FAXPHONE L80 Laser
Alarm button flashing says install cartridge. I put new toner cartridge in but after reset, unplugging etc the alarm light and message still come on? Thanks
first of all, check if the triangle on toner tube and toner insert is alligned. Eaven the smallest gap can cause the problem's because the nose on toner tube presses the sensor flapper and signals that toner is inserted.
Also the problem can be in broken sensor flap, or hardened toner in toner station.
If the toner station is faulty you can try to dismantlle the toner station and vacume it.
Hope that helps!
Sep 11, 2011 | Canon imageCLASS D761 Copier
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
How to refill toner in canon lbp2900 printer
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
May 29, 2011 | Canon LASER SHOT LBP-2900 Printer
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
I would Like to Know that how many pages the lates toner in the canon LBP2900B printer can print?
Canon LBP2900 uses 303 Cartridge Original Canon Cartridge prints 2000 A4 pages with 5% coverage
For more details click here to visit official product support
Hope it Helps! CreativeTECH
Dec 27, 2010 | Canon LASER SHOT LBP-2900 Printer
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
1,279 people viewed this question
old marine
old marine
