Question about Whirlpool Dryers
No heat, tumbles but produces no heat - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
3 Suggested Answers
  • 135 Answers
SOURCE: no heat coming out the tumble dryer
Electra is brand name for what was yeb so could have been made by several companys. Please check at back of drier for red reset button or rectangular plate at bottom right corner.
Posted on Dec 04, 2008
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
It still heats up and has not tripped the breaker,
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 12, 2010 | Whirlpool LER5636P Electric Dryer
Malber TD700 sensor tumbles but no heat
Common faults -
Jan 05, 2010 | Malber TD700 Electric Dryer
No heat from dryer
Common faults -
Nov 03, 2009 | Amana ALE331RAW Gas Dryer
Tumble drier tumbles but no heat its an Indesit...is it the thermostat
Common faults -
Nov 02, 2009 | Tricity Bendix TM310W Electric Dryer
Heats but won't tumble
There probably is a belt. Usually not too hard to replace if you have some basic screwdriver and mechanical aptitude. I've replaced several over the years and I aint no Maytag repairmen. Call your local parts house with the make and model and pick up a new one. Even if it's not your model you can probably find a utube video that will help make sense of it. Be sure to unplug the unit before working on it.
Sep 08, 2009 | Dryers
Tumble dryer borke
Common faults -
Jul 13, 2009 | Miele T8005 Tumble Dryer
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
No heat coming out the tumble dryer
Dec 03, 2008 | Dryers
Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
